Go to Post I guess it all just goes back to the fact that you need to finish your robot before it goes in the crate. - sanddrag [more]
Unread 15-05-2012, 21:05
Re: paper: LabVIEW Mecanum Programming
Originally Posted by xule View Post
I followed the directions (somehow I must have missed something).
If you double-click on the error, it should take you to the Case structure having the missing cases.
There are only two Case structures, right? The inner Case structure (inside the outer Straight case) should contain the True case you showed, along with an empty False case. The outer Case structure should contain a case for every possible value of the Rotation_mode enumeration. You're only showing us the Straight and L1 cases. Are any of the others missing?
