Thread Tools |
Rating:
Display Modes |
Re: FIRST is realy looking into the Einstein problems
I am a mentor/coach for a rookie team and I just have one question about the final 12 headed to FIRST. How many of the robots in question that lost communication during the matches had on-board cpu's? Its just a thought that might be an issue. One more x-file!
In reality "losing communications" is a catch all for what problems actually took place. We only know the robots stopped moving. We know (knew at the time) some of the robots that stopped moving were connected to the field and the RSL lights on the robots showed they were enabled. The problem(s) is(are) far more complex than you might think. Very few robots this year had on board computers in addition to the Crio. I inspected none in four events. Those teams that really wanted to incorporate the Kinect on the robot used them and a few others for vision processing. I don't remember seeing any on Einstein but it was pretty dark in the pit. |
As Al said, the "losing communications" catchall really envelops a lot of symptoms and issues, and ours -seems to- have been traced back to an individual robot issue. It is a tangled web indeed, and I do not envy those charged with unraveling it. As has been said before, I hope a bumpercrop of identifiable and repeatable issues pop up in June. Sorry to hijack the Einstein thread with a regional vignette, but I felt it was part of the greater picture. |
Anybody else experience this? Taylor is it possible that the firmware was corrupt? Had you tried re-flashing the router with the v1.4? Not to hijack the thread, but all of you can PM me with this info. Thanks.
Figuring out that it was specific robots that was causing the problem was tricky. We couldn't figure out how something specific to our robot was causing so many difficulties for all the other teams on the field, especially since we had already attended two other regionals, and run without a single issue at either. The FTA asked all the teams that seemed to be causing the field difficulties to check their firmware, and we realized it was the one thing we all had in common. Thinking back, I can't recall if it was something that inspectors checked that at the Championship. Does anyone else remember being asked router firmware at the Championship? It was one of the things that each Einstein team was asked in the questionnaire we filled out. Last edited by Holtzman : 17-05-2012 at 10:45. |
Re: FIRST is really looking into the Einstein problems
We had issues at SMR with 1.4 and stopped in 3 matches.
We made other changes also to reduce the CPU demand, but also downgraded to 1.21 and did not have problems at BMR or CHP. |
#7
This was noted back in March
http://www.chiefdelphi.com/forums/sh...1&postcount=35 |
#8
Sometime after Week 4 of regional competitons, CSAs were asked to check the WPA kiosk logs to identify teams with D-Link firmware version 1.40 and to watch for issues. Maybe not all of them got the memo.
#9
Just a thought, but I couldn't help but notice that there was a lot of spare time between when the divisions finished playing and the start of Einstein. It would be a good idea to have 6 bots from the divisions, that did not make it to Einstein, play a few rounds just to test the field systems? You could have a raffle to see which teams make it to the pre-Einstein "just for fun" event, this way the people in the stands have something to watch (although the paper airplanes were a good distraction
), and also if the field does have any issues you would be able to catch them before the first matches start. And you can just use leftover basketballs (or some other game piece for next year) from the divisions, so Einstein has a fresh field still. |
#10
At CMP, we ran laggy controls (robot responded 2 seconds after operator input, tons of dropped packets, long trip times) on 1.4. Downgraded to 1.21 and all was well.
#11
One additional data point to add to the pile that I don't believe was mentioned in any of this years previous "Communincations Issues" posts:
Specs: Bridge Firmware: 1.21 DS Laptop: HP Elite Axis camera Vision targeting through separate PC connected through ethernet into bridge C++ 4 port cRio When 2826 arrived on Archimedes for the first practice match: - We noticed an extremely high, relatively constant trip time (> 150ms) through the diagnostic tab on the DS. - Our FMS connection indicator would rapidly turn off and on and our axis camera feed was extremely lagged. - For the first 30 seconds, we were pretty much dead in the water. - We "jiggled" the ethernet connection and check CPU and network utilization, and the numbers were low and consistent with times where no errors ocurred - We then unplugged and re-plugged our ethernet connection to the DS laptop mid match. For an unknown reason, everything suddenly worked perfectly. No latency, no lag and full control -Afterward, the FTA mentioned that our trip time suddenly decreased per their diagnostics, so that was consistent For Practice Match 2: - We had the same rapid disconnection issues as match 1 as soon as we connected the ethernet cable to the DS laptop - The FTA came to us before the match was started and we tried unplugging and re-plugging the ethernet cable. This did not fix the issue, same symptoms - The FTA's curiousity was piqued, so he allowed a bit of troubleshooting - We could ping the bot with consistently high latency - We disabled and enabled the DS laptop network adapter - No fix - The FMS was rebooted - No Fix - Robot was rebooted - No Fix -DS laptop OS (windows 7, obviously) was restarted - At this point we had a completely new behavior in that we could ping the robot with low latency, but the FMS would not show connection. Quote from FTA "What the heck?! I've never seen this before" -We started the match anyway and had no control or feedback from/to the bot -About 10 seconds into the match, we disconnected and reconnected the ethernet cable and viola! Everything worked again. *At this time, we had a consistent set of failures and symptoms, but no consistent correction method. We were starting to freak out... For Practice Match 3: - Immediately prior to approaching the Alliance station, we rebooted the DS laptop -We waited for at least 1 minute for the robot and bridge to boot -We waited for the DS and dashboard applications to fully launch. -We confirmed that "2826" was established on the LCD board above our alliance station -We plugged in the ethernet cable into the DS laptop and got immediate connection to the robot and FMS. Little to no latency (<2-3 ms on average) -we ran the match with no glitches or issues At this point we knew our DS laptop was somehow perpetuating the issue, if not directly causing it. We ran the process described in 3 more practice matches, all Quals and elims with absolutely no issues. We know that we did not solve anything, but hopefully this process can shed some light on other noted issues. |
#13
Our robot has an on board cpu (Panda Board) for our on board Kinect and we never had any problems until Einstein. |
#15
Joe,
The CPU likely was not the problem but anything is possible. How did you interface to the control system? |
