Go to Post from time to time, we all need a good smack to make us see when we screwed up and did something we shouldn't have. - Andrew Schreiber [more]
Unread 16-05-2012, 17:49
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Bimba Cylinder Dimensions
Hello all!
I have been designing a custom two speed gearbox, and I have a question regarding the dimensions of the bimba cylinders.
What is the total length of this bimba cylinder while fully retracted? Fully extended?
http://www.andymark.com/product-p/am-0292.htm
What exactly is the difference between these two bimba cylinders?
http://www.andymark.com/product-p/am-0591.htm
Does the latter maintain an extended position when no air is pumped into the cylinder? If so, can the spring-style cylinder be used as a fail safe, in the event that the pneumatic system ruptures or the robot is undergoing a stall load situation?
Thanks everyone!
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
Unread 16-05-2012, 17:55
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Bimba Cylinder Dimensions
Go to McMaster and search "air cylinders"
You can select all your options.
One is spring return. You only need to put air in one direction. We have tried these in the past, the issue is that when shifting back in with the spring, the two sides don't spring right. And most of the time you don't have enough "spring" to shift under load.
For what its worth and how much air your consuming, your better off with the normal cylinder.
-RC
R.C.
MadTown Robotics Team 1323
Unread 16-05-2012, 17:57
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally Posted by Adam.garcia View Post
Hello all!
Thanks everyone!
The -R cylinder is a reverse single action cylinder (spring loaded in one direction), the -D is a double action cylinder (no spring).
For total dimensions and more explanations of these cylinders, see the Bimba website (they have CAD models too), and the catalogue.
Unread 16-05-2012, 22:50
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
I'd recommend the one shown at this link.
It's already used for the supershifter. If your design doesn't deviate too far from the AM model then it should be a good fit.
If you can't find the dimensions for this cylinder on the website, pm me and I'll measure the piston next time i'm in the shop (Saturday).
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 17-05-2012, 02:49
Design Mentor
I was planning on using this exact cylinder. However, I've been having problems understanding how the Poofs (254) have used this piston mount interfaced with the cylinder as you listed above to connect to the dog.
http://team254.com/resources/documents/cadpistonmount/
Since this piston mount seems to mount directly to the side plate, how does the piston connect to the dog gear? (On the super shifter, there is a big spacing between the face of the cylinder and the rod that connects the dog to the cylinder.
Unread 17-05-2012, 03:10
R.C.'s Avatar
Basically how 254 does it. They use that cylinder and it nose mounts/threads into that piston mount. From there it threads into a cone that pulls the rod that pulls the dog.
The only difference between 254's and the AM one is that this guy threads into a block while AM's requires a nut. Both setups do the same thing mechanically.
-RC
R.C.
Unread 17-05-2012, 03:24
Design Mentor
-RC
Hmmm, so as I understand it, their piston mount is firmly attached to the sideplate.
If that is correct, where do they have room to add the "cone" in the gearbox?
I would assume that the cone would have to be on the outside of the gearbox.
Unread 17-05-2012, 03:40
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The piston mount is attached via standoffs, so the shifter bearing block mounts between it and the sideplate.
2001-2004: Team 100
2006-Present: Team 254
Unread 17-05-2012, 03:51
Design Mentor
Ahh, this makes complete sense now. Just one final question: what is the reasoning for a "cone" shaped bearing block as RC had mentioned?
I've taken a look at 973's bearing block, and they use the exact same cone that has been mentioned here.
Unread 17-05-2012, 14:47
Build Lead
http://files.andymark.com/super-shif...-motor-cyl.stp
Here is a CAD file that should help you design the mount for the cylinder.
I haven't had a chance to look through it, but I think that it's the right one.
Unread 17-05-2012, 14:48
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Not much reason other than weight and aesthetics. The AM one is functionally identical.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 17-05-2012, 15:06
AdamHeard's Avatar
Lead Mentor
There is also the tradeoff in cost versus in house fab time.
Adam, what we did for our first series of gearboxes was reuse the AM shift shaft, block, mount plate, etc... We later switched to our own custom setup.
It may save you time and make the process a lot more painless by reusing his components, and going custom when you feel comfortable doing so.
Unread 17-05-2012, 15:34
Design Mentor
Alright, what we plan to do is make a custom output shaft, but reuse AM's dog and shaft assembly.
Thanks for all your input.
