Go to Post One of my management professors taught me this: At all times you are holding a bucket in each hand, one full of water, and one full of gasoline. Management is knowing when to throw which bucket. - Barry Bonzack [more]
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Unread 17-05-2012, 23:10
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Re: FIRST is really looking into the Einstein problems
Originally Posted by JB987 View Post
I agree with you, Al. Not likely that our on board cpu contributed to the "connections" issue but was just letting you know there was one robot on Einstein for sure that was using cpu. It processed Kinect data and sent key data to Crio over router. The Crio then sent info to driver station via the bridge. As I recall, programmers had compacted data so it would be sending reduced data packets and avoid over loading transmissions.
When you say that the computer processing the Kinect data sent key data to the cRIO over the router, I'm assuming you mean the switch on the bridge, right? The only real device with routing tables in the standard control system is the field access point.
