Go to Post I'd rather have a bot in front of me than a frontal lobotomy. - Neal Probert [more]
Unread 17-05-2012, 22:44
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
pic: My After Thought #6
Unread 17-05-2012, 22:47
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: pic: My After Thought #6
Hmmmmm..Fisher Price for drive. I thought of this a while back but got shot down because apparently the FP's heat up like below 50% power or something.
Looks great so far!
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 17-05-2012, 23:26
Chris is me's Avatar
AKA: Pinecone
I don't think a 4 FP drivetrain would be a great idea. The CIMs are much better suited for the large forces, stall / near stall conditions, and heavy use of a drivetrain.
Unread 17-05-2012, 23:40
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
As much as I agree with the statements above about how FP motors in the drive can only end poorly, I feel compelled to mention that these motor were designed to act as the drive motors in kids cars. So, if you did the math to cool them properly, ensured they had a ridiculous gear reduction and NEVER went in a pushing match you might be able to make it through qualifications without replacing them.
Just my two cents...
Dan K
Unread 17-05-2012, 23:46
CalTran's Avatar
CalTran CalTran is online now
Missouri S&T Senior
I can only echo the statements of FP motors in the drive. Unless you had plans for the CIMs elsewhere that take precedent, I suggest you reallocate them to the drive. Also, that is one interesting shooter. If I'm looking at it correctly, it would appear to be that the ball would have minimal contact between both the wheel and the compression hood. Correct me if I'm wrong please.
Academic Student (Forever)
Unread 18-05-2012, 07:05
ttldomination's Avatar
Sunny
I don't see your CIM motors in the CAD? Mind sharing about where they are being tasked?
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 18-05-2012, 12:15
1502's Avatar
AKA: Ryan G
The FP's were just a different idea instead of using cims. This wouldn't be meant for any heavy duty pushing matches; just to go pick up balls and get on the bridge. This setup was actually lighter than using cims and I'd never done it before so I thought I'd try it. Also we've used FP's before on a magic carpet for a school play and didn't have any problems there. There would actually be about 3 inches of compression in the hood so it's sufficient.
We make easy things look difficult, everyday!
Unread 18-05-2012, 13:23
Joining the 900 Meme Team
FRC #0079
Pushing isn't the only time you pull a large amount of current. Be sure to gear very conservatively or the likelihood of you frying a FP motor will be very high when accelerating (read, changing direction or starting moving). Honestly, the benefits of using a CIM is that they are darn near bulletproof and stand up to all manner of abuses.
CAN you use the FP motors? Sure! I just think that it would make more sense to use the CIMs for the task they are really good at and save the really high RPM FP motors for something they are better used for.
Unread 21-05-2012, 16:29
1502's Avatar
AKA: Ryan G
Do keep in mind this is just an idea and probably not going to happen; Just things that come out of my brain. So no need to beat a dead horse
Unread 21-05-2012, 19:33
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Actually, the second set of mounting holes on the FP transmission is the proper spacing for the 775s so all that you need is an appropriate pinion to make it work (this can be obtained by boring out the pinion that came with the FP motor). We did it in 2011 for our arm and it is a very good combination that, if done with four motors as shown here, could actually work quite well for light to medium driving. The 775s are much less prone to heating and should tolerate it, just have some extras on hand.
EDIT: What's the deal with the CMU cam 2? Is it supposed to represent the axis camera or would you actually use a CMUcam?
Unread 21-05-2012, 20:02
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Very detailed drawings, What program allowed you to do this as i would love to use it.
Unread 21-05-2012, 21:52
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Judging by the fact that he cites Inventor Physics, he used Autodesk Inventor.
This CAD software is free to FIRST teams at the link below.
http://students.autodesk.com/?nd=first_home
There is also a basic tutorial located here.
http://wikihelp.autodesk.com/Invento...uilt_by_Design
Have fun
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 22-05-2012, 15:15
who716's Avatar
Have fun
Much thanks
Unread 22-05-2012, 16:59
1502's Avatar
AKA: Ryan G
Yes, this is 2012 Inventor. It's the standard rendering feature.
It was the only camera I had on file so I used it.
