Go to Post ...I pretty much got the impression that the balls are actually very small, cuddly landmines. - Gui Cavalcanti [more]
Unread 10-01-2003, 23:11
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
Question compressor?
I looked into the rules and It never stated that we NEEDED to use the compressor. I figured that some of you might know the answer to this. Is it mandatory that we use the compressor that was provided in the KIT.? and can we use more then one linear actuator.??
Thanks
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Unread 10-01-2003, 23:31
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
yes it is
You must use the compressor provided in the kit. If you follow the part use flowchart, since a compressor has a motor, you can not use another compressor besides the one in the kit.
However, If you only need a small amount of air for your application, you can just put the storage tanks on the robot and then charge the tanks before each round.
Also, you are allowed 3 custom cylinders from Smc and the one in the kit.
Unread 11-01-2003, 18:18
Jim Harbison Jim Harbison is offline
#0484 (lron lammas)
Jim Harbison is an unknown quantity at this point
Free storage tanks
We used the rectangular AL for our frame and installed sealed (rtv) bulkheads fastened with rivnuts then put ports where we want them in the frame and use the frame as a storage tank.Might freak the other teams out cause it so creative.But thats what robotics is all about.
Keep creating.
Jim H
Unread 11-01-2003, 18:51
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Free storage tanks
Originally posted by Jim Harbison
We used the rectangular AL for our frame and installed sealed (rtv) bulkheads fastened with rivnuts then put ports where we want them in the frame and use the frame as a storage tank. Might freak the other teams out cause it so creative.But thats what robotics is all about.
Keep creating.
That is explicitly against the rules. If you did it in prior years, you are lucky that you got away with it. Whoever inspected your robot at the competition slipped up. You might not like it stated this way, but consciously or not, you were cheating.
The applicable rule last year was Rule M13. It explicitly stated that custom built pneumatic components were prohibited.
This year, the applicable rule is unchanged. Rule M12 states: Only items listed under the PNEUMATICS section of the Kit list may be used to STORE, generate or transmit compressed air or vacuum, with the following exceptions:
- Suction cups may be fabricated from legal Kit parts, as defined in rule K1 below,
- Tubing may be compressed in order to block the flow of air,
- Tubing may not be compressed in order to generate compressed air or vacuum,
- Only the allowed air cylinders may be used to generate vacuum
Yes, the practice of sealing bulkheads into aluminum tubing and storing compressed air in them will "freak the other teams out" - but not because you are being creative. They will react, and appropriately so, because you are violating the rules that they are obeying.
Unread 13-01-2003, 22:23
Andy144's Avatar
Andy144 Andy144 is offline
#0006 (Cogsquad)
Andy144 is an unknown quantity at this point
Send a message via AIM to Andy144
Creating a vacuum
By backdriving (i think that is term) the piston you create a a vacuum. Just attach one of atwoods to the 2.5" bore piston pull it out and a vacuum is created. Just attach some rubber tubing to the opening of the piston and run it into the suction cup.
Unread 15-01-2003, 19:46
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
suction
but would the suction be strong enough to hold a crate, and would the cup hold? the boxes have lips, and it would really suck (no pun intended) if you set it up, but then, lets say, an upside down box would not line up properly. also with the issue of no compressor, I'd be concerned about air leakage from the time you leave the pits to the time you actually match, and if you only have limited air, you might not get the job done that the pneumatics would be intended for, with maybe only 5-6 times that you could use a pneumatic cylinder, and less if it was large.
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 15-01-2003, 20:03
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
It really depends on what size cylinder you back-drive and how much air you start with in the system, as well as the size of your suction cup and the quality of the seal it makes with the box. If you want to calculate the amount of force you will be able to exert, you're going to need the following equation:
P0*V0=Pf*Vf, where P0 is the initial pressure of your system (usually 1 atm), V0 is the initial volume of air in the system, Vf is the final volume after extending the cylinder, and Pf is the final pressure of the system. Thus to calculate your sucking power, subtract Pf from P0 to get the pressure difference from atmospheric. This will be the number of psi your suction cup holds with. Multiply this by the area of your cup and you will have a decent estimate of how much sucking power you have.
As a side note, 1atm is approx 14.1 psi if I remember correctly.
--Rob
Unread 15-01-2003, 23:07
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
We just messed around with this today. We brought in a vacuum pump and tried it. It does hold quite well and say -60 to -70 lbs. They cylinder provided in the kit can create about -90lbs at full stroke. It could be more if ours had leaks.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 21-01-2003, 16:29
Bob Steele's Avatar
AKA: Bob Steele
Question Legal number of cylinders????
We have discussed the wording for the legal number of cylinders.
Some threads have said it is four as long as you use the one that is in the kit but others are interpreting the rule to mean 3 TOTAL cylinders.
This is a change over last year...
any interpretations???
thanks
Bob
Unread 21-01-2003, 17:42
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: Legal number of cylinders????
thanks
Bob
Bob,
Check this thread out.
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 21-01-2003, 17:51
Re: Re: Legal number of cylinders????
More specifically, check out this post: http://www.chiefdelphi.com/forums/sh...r=2#post117752.
Unread 22-01-2003, 07:12
Bob Steele's Avatar
AKA: Bob Steele
thanks
Thanks guys!!
That clears the question up.
Thank you for being helpful!!
Problem with compressor Nick R. Pneumatics 3 21-02-2003 10:51
compressor Greg Needel General Forum 2 14-02-2003 07:50
Air compressor never shuts off Carl Owenby Pneumatics 4 08-02-2003 23:34
compressor questions Greg Needel Pneumatics 2 29-01-2003 16:58
programming the compressor archiver 2001 4 23-06-2002 23:19
