Go to Post this is ridiculous, a complete waste of time, and probably not particularly effective. I love it! - The other Gabe [more]
Unread 20-05-2012, 09:59
Robogineer1649's Avatar
Robogineer1649 Robogineer1649 is offline
AKA: Adam Molnar
FRC #1649 (E.M.S.)
Team Role: Driver
Robogineer1649 will become famous soon enough
Bridge Manipulator
I have seen three types of bridge manipulators triangles like 846's robot, i have seen just straight metal pushing down on the bridge like 233's robot, and i have seen wheels like our robot 1649's robot. I was wondering what type of bridge actuator you used if I missed it and which bridge manipulator worked the best. I know that all three types were able to get the bridge down but I want to hear your pros and cons for each bridge.
I like the triangle manipulators because you don't have to push down on the bridge you can just lower the manipulator and drive up and over.
Unread 20-05-2012, 10:17
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Re: Bridge Manipulator
Sorry to ask, but aren't the "triangle" from 846 and the "straight" wedge from 233 just different implementations of the same thing? They are both passive manipulators, unless I have misunderstood the design of 233's system.
Either way, we had passive wedges with a triangular arm on each edge of the robot and a lexan strip between them. We also had locks on each arm so we could put all our weight behind the manipulators. Except for the rare time when the lock failed to engage correctly, we barely had to slow down to climb the bridge. We were very happy with their performance overall.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 20-05-2012, 10:32
ttldomination's Avatar
Sunny
Our bridge manipulator was a passive-wedge style with a gate lock to hold it down.
I have to say, our robot was full of inconsistent components, but the bridge manipulator worked better than we could have hoped.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 20-05-2012, 10:37
AKA: Adam Molnar
FRC #1649 (E.M.S.)
Team Role: Driver
They are both passive bridge manipulators but they are different designs one was built directly just to push down on the bridge while the other one was built to push down the bridge as the robot approached it.
Unread 20-05-2012, 11:08
sleepyizme's Avatar
sleepyizme sleepyizme is offline
AKA: Jason
FRC #0694 (StuyPulse)
sleepyizme is an unknown quantity at this point
Send a message via MSN to sleepyizme
My team had a "passive" manipulator that was essentially two thick sheet metal tusks put together, lowered by a single pneumatic piston (we changed it from the original picture). This let us drive straight into the bridge without stopping, saving us precious time, but we were also able to lower the piston when the Joebot was right in front of the bridge, so it could be used "actively."
You might notice that the top of the tusks is very close to the edge of the bridge. Every once in a while, we encountered an issue with the tusks driving under the bridge and pushing it up.
Unread 20-05-2012, 11:14
Ekcrbe's Avatar
AKA: Erik Boyle
Originally Posted by Robogineer1649 View Post
... one was built directly just to push down on the bridge...
So this would make it active, not passive, right?
Unread 20-05-2012, 11:18
AKA: Adam Molnar
FRC #1649 (E.M.S.)
Team Role: Driver
Correct
Unread 20-05-2012, 11:34
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
See this thread.
Originally Posted by slijin View Post
118. Their entire frame was built for passive bridge manipulation - both pushing it down and lifting it up - and a good portion of their mechanisms were devoted to balance assists. They had a beautiful system to assist a double balance, complete with lights to indicate an unbalanced v balanced bridge. And that's all before their stinger.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 20-05-2012, 12:02
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
http://youtu.be/g_7ljqbIdi8
Unread 20-05-2012, 15:25
sebflippers sebflippers is offline
FRC #2914
sebflippers will become famous soon enoughsebflippers will become famous soon enough
I believe we (2914) had a really unique system. Just drive into the bridge to tip it the other way, or drive back then forwards and it will swing right to us.
Unread 20-05-2012, 15:37
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
3397 had a "hammer" (actually it was a pvc arm with an elbow joint) on our robot that was powered by a Fisher-Price motor with the standard KoP gearbox. It worked beautifully.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 20-05-2012, 15:43
Chinmay's Avatar
Chinmay Chinmay is offline
incurable FIRSTaholic
FRC #0846 (Funky Monkeys)
Chinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant future
Like someone mentioned, we were subtly different from the triangular wedge. Here is a short report that explains the design considerations
http://f.cl.ly/items/3l203Z2v272J1n3...her_Report.pdf
Member 846 Funky Monkeys 2007-2011
Mentor 558 Robosquad 2012
Mentor 846 Funky Monkeys 2011-Present
http://www.becauserobots.org
Man is a robot with Defects
Unread 20-05-2012, 15:47
CalTran's Avatar
CalTran CalTran is online now
Missouri S&T Senior
Is the manipulator we're looking at supposed to be the "roll cage" like polycarb or the piece of aluminum somewhat under your shooter?
Academic Student (Forever)
Unread 20-05-2012, 20:52
MIT_MAN's Avatar
MIT_MAN MIT_MAN is offline
Join the kevolution!!!
AKA: Tommy Ikuss
FRC #0025 (Raider Robotix)
MIT_MAN is a jewel in the roughMIT_MAN is a jewel in the roughMIT_MAN is a jewel in the roughMIT_MAN is a jewel in the rough
Our wheelies were incredibly consistent with lowering the bridge... even in autonomous
Raider Robotix F.I.R.S.T Team 25
2012- World Champions!!!
2012- Mount Olive and MAR Championships Winners
2011- Virginia and Newton Winners
2010- New Jersey and Vegas Winners
Unread 20-05-2012, 21:08
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
We used our cannon to get the bridge down. Worked every time!
