Go to Post Now if you'll excuse me, I need to develop the edible transistor. - sciguy125 [more]
Unread 20-05-2012, 23:03
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Outdoor Robot
Our team is planing on building a tennis ball shooting robot for our host organization. It is going to have to go through camping conditions, dirt, mud, sand, and alital bit of water . It will have people with limited to no robotics experience operate and maintain it.
I want it to have a super simple electronics and battery interface so that it can be charged/change batteries super easily. It also needs to have fail safes because it will be in operation near kids and were trying to incourage them to join our team, not fear us.
Could you tell me any of your suggestions?
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 20-05-2012, 23:58
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Outdoor Robot
Put the electronics in surplus military ammunition boxes, the lids can be removed for operating and they have a watertight seal. Also, they are easy to come by, surplus center almost always has them.
Edit: these are a bit wider, and I have first hand experience with them and know that they are good boxes. The ones I linked to before are only 4 inches wide and look rather thin compared to the .50 cal boxes
Unread 21-05-2012, 00:31
JonathanZur1836 JonathanZur1836 is offline
FRC #1836 (The Milken Knights)
JonathanZur1836 has a spectacular aura aboutJonathanZur1836 has a spectacular aura about
Re: Outdoor Robot
You don't want dirt & mud in your transmission, so I suggest building something with minimal chain & protected gearboxes. Also, if your motors are going to be running constantly, you may want to find some way to cool them.
[size="2"][b][font="Tahoma"]Team 1836 - MilkenKnights
Unread 21-05-2012, 00:56
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Outdoor Robot
Remember, weight doesn't work against you too much in this design.
Keep it simple, keep it safe.
Maybe use some RC Car parts to keep the electronics cost/complexity down?
Unread 21-05-2012, 01:37
AKA: Voltonless
FRC #3260 (SHARP)
Re: Outdoor Robot
I was planing on using a vex cortex with joystick and partner joystick. For motor controllers I was thinking of using victors and vex spin controllers. Anything better than this that you can think of? And is there a good alternate to CIMs for drive-train?
Also thanks for the suggestion for the ammo box, what would be the best way to waterproof any holes for wires, hotglue? And any ideas on keeping the battery away from derbies without putting it in a metal box ,dont want it shortcircuting.
Team SHARP
Unread 21-05-2012, 03:40
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Outdoor Robot
When I used them for a similar purpose I cut a piece of plywood that fit in the bottom of the box and attached foam-core board on the four sides to create a box within a box. Unfortunately I never finished them (maybe I will this summer) so I have no photos for reference. For wires I would recommend a silicone based sealant . Your local boating supply shop should have something suitable. If the silicone proves to be too weak, you can try polyurethane instead, but then you sacrifice the convenience of soap and water clean-up. Blends of the two are also available.
Unread 21-05-2012, 06:28
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Outdoor Robot
Something similar to this would work well for electronics, and you can find one to mount the battery within. I would use caulking to waterproof any holes you might need to cut.
These cases are meant to be exposed to the conditions you described, and come in nearly any size you can imagine.
Unread 21-05-2012, 11:20
R2D2DOC's Avatar
R2D2DOC R2D2DOC is offline
AKA: Laszlo Hideg
no team (Judge & Volunteer)
R2D2DOC will become famous soon enoughR2D2DOC will become famous soon enough
Re: Outdoor Robot
Consider competitions such as IGVC as a resource: www.igvc.org This is a university level competition that is run outside on a grassy field rain or shine.
Unread 21-05-2012, 12:26
pathew100 pathew100 is offline
AKA: Pat Murphy
FRC #0862 (Lightning Robtics)
pathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud ofpathew100 has much to be proud of
Send a message via AIM to pathew100
Re: Outdoor Robot
Please use silicone sealant that is rated for use in an electronics environment. The stuff you normally get at boating shop and your local hardware big box store
are not. The sealant off-gases acidic compounds as it dries and hardens and this will corrode electronics.
Unread 21-05-2012, 12:40
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
Re: Outdoor Robot
This. Use RC for the controls system, if you can. From what I hear, almost no programming is required. It's all about frequencies.
Unread 21-05-2012, 19:04
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Re: Outdoor Robot
if you want to go all out you could make one of these for the electronics.
http://imgur.com/a/wX5Dz (this is not my work)
if you do post pictures, actually you should post pics whatever you do.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 21-05-2012, 19:14
AdamHeard's Avatar
Lead Mentor
Re: Outdoor Robot
RC is a good suggestion, as receivers are tiny and anything 2.4 ghz is very safe, reliable, and plug & play. A v-tail mixer sold for airplanes is also a "tank drive mixer" for arcade style driving.
Traxxas brand RC cars have waterproof housings for receivers that can be had on ebay for $5, very useful guys.
I'd recommend you take a good look at things that require grease/lubrication and try to minimize them. Exposed chain on this will be a dealbreaker in the long run.
Unread 21-05-2012, 23:09
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Outdoor Robot
This.*
Also, I would like to change my recommendation to Sugru. Not only is it designed to be compatible with electronics, but it also molds like playdough and comes in green (and red and blue and...)
*[I assumed that it would be done with the electronics out of the boxes, but I shouldn't assume things]
Unread 22-05-2012, 00:23
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
Re: Outdoor Robot
little kids+nobody around that knows robots well+pinch points=lost body parts. Lets face it, the kids you want to recrut are the ones that will take the chaingaurd off to watch the chain and those same kids will likely forget to put it back...
to put it nicely: if there is something dangerous you can get to, kids WILL get to it sooner or latter. chains and gears have to be accessible so they can be greased. chains and belts have to be accessible so they can be put back on if they come off or break. If you have to have these things, bolts with unusual heads (and maby a lock washer or lock nut or both) is a good idea to slow kids down.
also, stay away from small bolts as the heads strip faster the smaller they are and don't have wires within drill length of bolts... we don't want someone thinking they are being smart and drilling out a striped bolt and accidentally electrocuting themselves/shorting it out/ stopping the robot from working.
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 22-05-2012, 03:18
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Outdoor Robot
if you run the chain through aluminum box tubing then there is no way to get to it without making it un-dangerous
