Go to Post "When I joined the team, I was told that we'd be in the shop for six weeks. I STILL haven't seen a single boutique, and now they have me dumpster diving for robot parts! I quit!" - EricH [more]
Unread 22-05-2012, 00:23
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
Re: Outdoor Robot
little kids+nobody around that knows robots well+pinch points=lost body parts. Lets face it, the kids you want to recrut are the ones that will take the chaingaurd off to watch the chain and those same kids will likely forget to put it back...
to put it nicely: if there is something dangerous you can get to, kids WILL get to it sooner or latter. chains and gears have to be accessible so they can be greased. chains and belts have to be accessible so they can be put back on if they come off or break. If you have to have these things, bolts with unusual heads (and maby a lock washer or lock nut or both) is a good idea to slow kids down.
also, stay away from small bolts as the heads strip faster the smaller they are and don't have wires within drill length of bolts... we don't want someone thinking they are being smart and drilling out a striped bolt and accidentally electrocuting themselves/shorting it out/ stopping the robot from working.
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
