Go to Post I think we all should strive to be better than what is expected of us. :) - Madison [more]
  #31   Spotlight this post!
Unread 11-01-2003, 00:53
J MacAllister J MacAllister is offline
#0125 (Nutrons)
J MacAllister is an unknown quantity at this point
Lightbulb Paul's calculation clarification
I would recommend that anyone hazy on this stuff take a look at Paul's presentation. I had the sign of the slopes wrong, so my earlier remark that the drill motor power @40A should be 44% of the maximum power was incorrect. Turns out to be more like 82% of the maximum power (which is much nicer). Thanks again, Paul.
-- Jeff
  #32   Spotlight this post!
Unread 11-01-2003, 01:28
#0125 (Nutrons)
Question Question on Paul's Presentation
In the derivation for the maximum velocity near the end of the slides, it defines a 0.9 for "drive friction slowing the robot down". However, there is already an "eff" (efficiency) defined for drive losses. Is the extra 0.9 meant to account for rolling friction, or something else?
-- Jeff
  #33   Spotlight this post!
Unread 11-01-2003, 10:46
BerserkerSpyke's Avatar
BerserkerSpyke BerserkerSpyke is offline
#0871 (Robotechs)
BerserkerSpyke is an unknown quantity at this point
So what is the torque of the drill motors at high and low speed?
  #34   Spotlight this post!
Unread 11-01-2003, 10:50
President, VEX Robotics, Inc.
Fudge Factor
It is a total fudge factor accounting for the loss of speed due to drive friction.
If you notice, only the torque is effected by efficiency. So, in theory, you could achieve the free speed of the motor. In reality, the drive friction will also slow you down to something less than free speed.
The actual equation that this comes from is:
F= ma + Ffdrive
You can derive top speed from this equation. Ffdrive is the friction losses in the drivetrain. What we do is disconnect the motors and pull on our robot with a spring scale at constant (approx.) speed.
Historically, we see 10% losses in the calculated free speed.
-Paul
  #35   Spotlight this post!
Unread 11-01-2003, 10:54
Figure it out yourself
BerserkerSpyke,
Read my presentation. Use my motor numbers. Take apart the transmission and count the teeth in the planetary gearbox. Use the equations I gave you in the presentation and determine it yourself.
The reason I don't have the transmission numbers is due to the fact that we will not be using the transmission. We make our own.
-Paul
  #36   Spotlight this post!
Unread 11-01-2003, 12:38
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Also, I got a lecture note I give to my students when I teach them about motors. It's here:
http://www.chiefdelphi.com/forums/sh...threadid=15479
I will upload an updated one really soon that fix all the grammar error in it, but this one should show you the correct information. It's basically base on Chief Delphi's motor presentation, only the missing details from the power point.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
  #37   Spotlight this post!
Unread 11-01-2003, 15:27
Umm Errr...
hmm looks like we will have to beg steal buy or borrow a tach and a torquometer. no clue how to spell that.
1139 Alumni
  #38   Spotlight this post!
Unread 11-01-2003, 16:11
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
I wasn't doubting you, just making sure
The advantage of the "Chalupa" motor is it's ability to run at 100% duty cycle (or closer to 100 then the drills)? I'm assuming it is larger because the winding wires have a larger radius giving them less resistance...?
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
  #39   Spotlight this post!
Unread 11-01-2003, 20:18
#0125 (Nutrons)
Lightbulb Answer to BerserkerSpyke
See the attached file. I modified a slide in Paul's presentation to deal with the high and low speed modes of the Bosch drill motor.
-- Jeff
  #40   Spotlight this post!
Unread 11-01-2003, 20:26
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Talking
torquometer
A torquometer?????? All you need to calculate torque is a shaft attached to the motor at the length you want your units at and a scale.
  #41   Spotlight this post!
Unread 12-01-2003, 10:27
Drill transmission
Jeff,
Good job on adding the drill transmission numbers. I will add them to my preso.
It doesn't look like you included efficiency of the gearbox in your torque calculations. In high torque, it should be .95*.95*.95 and in low torque it should be .95*.95.
Paul
  #42   Spotlight this post!
Unread 12-01-2003, 10:56
#0125 (Nutrons)
Question Efficiencies of Bosch Gearbox?
I thought they'd be included automatically, since I used the output RPM (450, 1500) instead of the actual RPM calculated by the 42.62:1 and 12.07:1 gear ratios (which give you 461 and 1629 RPM, respectively). But I'm often wrong.
-- Jeff
Robot output torque Alex1072 Technical Discussion 9 12-03-2003 22:13
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
How fast could a torque motor turn if a torque motor could.. archiver 2001 0 23-06-2002 22:54
Traction Limited, rather than torque Simon G Technical Discussion 6 23-01-2002 07:08
