Go to Post While youth is wasted on the young, in FRC knowledge can be wasted on those a bit older. - IKE [more]
Unread 02-01-2002, 14:54
Ydnar's Avatar
Ydnar Ydnar is offline
#0932 (Circuit Chargers)
Ydnar is an unknown quantity at this point
Send a message via AIM to Ydnar
How do you make objects shine???
I was working on an animation and i came to something i just could'nt figure out in any book or tutorial, well atlease looking throught them roughly, But i was wondering out to make an objetc shine, like chrome or maybe even make an object like mirror, if you can help i would greatly appreciate it. thankz
-Come and go, and rise and fall with glory, maybe one day i'll be famous too
Unread 02-01-2002, 17:34
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
Shine
Fairly simple effect. It's called Raytracing.
I suggest Pg. 84 of the tutorial that came with MAX 4.
Unread 02-01-2002, 20:54
Ydnar's Avatar
well can you tell me please becuase i'm currently unable to get to the tutorial book, any help would be great...
Unread 02-01-2002, 21:31
Pamela's Avatar
Pamela Pamela is offline
Half the JVN,All theTaste
Pamela has a spectacular aura aboutPamela has a spectacular aura aboutPamela has a spectacular aura about
Send a message via AIM to Pamela
can't you just go into the materials editor, into the mtl library and attach the material to the object? I haven't played with the program for awhile but I remeber them having metals and glass and stuff like that in the library.... Then you just shine a light on it I guess?
~Pamela, Alumni of 166 and 229
Unread 02-01-2002, 23:26
Post Raytracing
I took some screenshots and added text to the images. Take a look.
By the way, to open the dialog in the second image, select an empty material slot, and click the "Get Material" button shown in the first image.
Link
The second image is related to what Pamela said.
So you're trying to make chrome? You can do it without raytracing, too. Try the "metal" file referred to in the second one.
Unread 03-01-2002, 00:11
Ydnar's Avatar
thank you, this will help alot, thank you a bunch
Unread 03-01-2002, 01:41
Any time.
Unread 07-01-2002, 21:13
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
Raytracing
Raytracing is very very bad for us, as it boosts render time through the roof for nominal gain. An easy trick is to map a still image approxomating the thing you need to have reflected into the reflection slot of your material and bump up the specularity. Doing that gives an effect approxomating that of raytrace reflection maps without the debilitating render time hike, especially when the resolution doesn't support effects that subtle.
Threads getting too long to make sense of Ken Leung CD Forum Support 22 05-05-2005 01:14
Using Flash to make an animation? Ryan Dognaux Computer Graphics 1 27-02-2003 17:06
Map Coordinates on imported objects Jacob Reif 3D Animation and Competition 2 04-02-2003 01:27
Help - objects won't move in Max Kevin Thorp 3D Animation and Competition 7 28-01-2003 12:49
Please help make the Nationals in Houston AWESOME ... You be the Tournament Director Natchez General Forum 42 13-12-2002 18:50
