Go to Post While we're on the topic of games... there have to be some people who'd be interested in a good round of FIRST ROBOTICS!!!!!!!!!!!!!!!!!!! :p :yikes: :D :rolleyes: - Leav [more]
Unread 22-05-2012, 12:20
yottabyte's Avatar
yottabyte yottabyte is offline
AKA: Clayton
FRC #4334 (Alberta Tech Alliance)
Team Role: Electrical
yottabyte is on a distinguished road
Terminal blocks VS Quick disconnects
What are some of the advantages and disadvantage of each?
2015 - Utah Regional Winner
2014 - Western Canada Regional Regional Winner
2014 - Western Canada Regional Regional Chairman's Award
2013 - Western Canada Regional Regional Winner
2012 - Indiana Robotics Invitational Winner
2012 - Archimedes - Championship Division Winner
"If the women don't find you handsome, they should at least find you handy."
Unread 22-05-2012, 12:25
lpickett's Avatar
lpickett lpickett is offline
Linda Pickett
FRC #1730 (Team Driven)
lpickett is a jewel in the roughlpickett is a jewel in the roughlpickett is a jewel in the rough
Re: Terminal blocks VS Quick disconnects
Speaking as an electrician, it depends on what you are using this for. Both can have problems with loose connections. You need to make sure your quick connects are either soldered or crimped completely. We have been know to do both to ensure a good connection. That is what my husband has taught our students when making the battery connections. We have not had any issues that I know of (except if they use the cables to carry the battery and break wires). The terminal blocks can loosen up over time with a lot of jostling and bumping. They should be tightened every so often to ensure no loose connections. You also might use a ring connector if your connector does not have a clamp part to it.
Unread 22-05-2012, 22:04
DonRotolo's Avatar
Back to humble
FRC #0832
Terminal blocks tend to exhibit lower connection resistance than any kind of connector, and are considered to be more reliable. But terminal blocks take longer to disconnect.
This applies only when they are being used properly, in accordance with the manufacturer's recommendations.
Unread 22-05-2012, 23:01
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
The obvious advantage of a quick disconnect is that we can quickly swap out parts. Our team usually only uses this connection for disconnectable subsystems, or motors that like to burn out.(cough, cough banebots...). Although not really related, you can use quick disconnects so that pairs of wires can only be connected in one way, and you can easily find color-coded disconnects as well.
Terminals are mountable (depending on the terminal), and make solid, low resistance connections. We use these for things like power to sensors, camera, and other things whose wiring is not likely to be changed/removed. A little super glue (or nail polish for a strong but temporary hold) can ensure an "out of sight, out of mind" connection that can be hidden inside a robot.
Unread 23-05-2012, 00:08
abaileyb123 abaileyb123 is offline
FRC #1515
abaileyb123 is on a distinguished road
Here at team 1515 we use quick disconnects throughout our entire robot. I am the electrical captain and for the past 4 years (3 of which I was a part of) we have utilized modular electronics boards. The advantages that these boards bring are numerous. Easy to matinence / replace components, easy to remove components when shavings could be involved, programmers can have the electronics to play with while builders work on the robot itself.
Are whole system revolves around the WAGO Xcom series connectors. We use a 2 tiered system which can support any number of wires. The way they work is similar to a terminal strip, yet they are fully modular. I see someone mentioned resistance is lower for terminal strips, I haven't researched the resistance imposed by the XCOMs but it has not been a problem. I recommend that teams look in to this system and consider implementing it in future years.
Unread 23-05-2012, 01:09
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
My experience with the terminal blocks has been nothing but loose connections. They never seem to stay tight. I'd avoid them at all costs on an FRC robot.
Unread 23-05-2012, 01:19
yottabyte's Avatar
AKA: Clayton
who was the manufacturer of Terminal blocks?
Unread 23-05-2012, 03:18
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Can I see some pictures of how you have implemented it? It looks like a very diverse system and it looks like it could get pretty heavy.
Another thing to note is that many (I would cautiously say most) terminal block systems are designed for stationary mounting on a factory floor, i.e., a (nearly) vibration free environment. Automobiles (and just about any other mobile vehicle) almost exclusively use quick-connects.
Jason
Unread 23-05-2012, 09:02
Clayton,
This question is better answered when aimed at a particular use.
If you are asking about a First robot, then different terminations are often used for different applications.
We use Power Pole for most motors to make them easy to replace. We have the correct crimper and then follow with a bit of solder for insurance. We use spade terminals on Victors, uninsulated, crimped and soldered then heatshrink for insulation. The same for female pushons used on Spikes. For PWM styles, we have the military crimper for those connections. We use D connectors for many of the other connections all soldered.
Unread 23-05-2012, 11:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
As Al says, the application helps determine what you need. If it's a prototype that you'll probably be playing with the wiring on, then terminal blocks can be handy.
Unread 23-05-2012, 11:34
FRC #1836 (MilkenKnights)
1836 is very good friends with 1515, and I know that the system is heavier(maybe 3 lbs extra), but they really like the modularity. It uses 4 of the wago blocks, and makes it very easy to add/subtract/change any wiring on their robot.
Unread 23-05-2012, 12:38
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I didn't find any pictures of the system as implemented on 1515's robots (still searching); however, you can see the type of terminal block they use on page 56 of 1515's build manual.
BTW, that is a really great document.
Richard Wallace
since 2003
