Go to Post I think rovers on Mars are way cool but you won't get a crowd of enthusiastic participants cheering as they trudge 150 meters a day. - Andrew Schuetze [more]
Unread 23-05-2012, 13:37
Re: The physics of pushing
Originally Posted by Ken Streeter View Post
For robots with high torque capabilities and very grippy wheels, "lift up" seems to be the limiting factor.
Assuming you're pushing against an identical robot, this limits pushing force F to approximately (W*k-tau)/h, where h is the height (above the horizontal witness line through the center of the wheels) of the effective contact point of the pushing force and tau is the torque on the rear wheels
Note that if F is below the horizontal witness line through the center of the rear wheels, then "h" is negative.
corrected diagram
original diagram
ID:	12783  Click image for larger version
Name:	push (original diagram).png
