#16
Re: Outdoor Robot
If you are going to be around little kids you might want to consider firing something besides tennis balls. And you certainly want to carefully consider exit velocity, firing safeguards, etc.
For that eventual day when someone gets hit (and it will happen) you want it to be something soft and/or very low velocity. A high speed tennis ball could actually do some serious damage. |
#17
Re: Outdoor Robot
I won't speak to the electrical side, as others are much more qualified. We're working on this approach for a baseball pitching robot at the request of the local minor-league baseball team. I'll post photos when done. |
#18
Re: Outdoor Robot
Thanks everyone for your help!
I'm thinking we will use the ammo boxes for the electronics and the pelican boxes for the batteries. Any holes Ill cover over with Sugru. To shoot, nerfballs, and cover the whole thing in lexan. And also I think we will use tamper proof screws so that no-one can unscrew anything. Do you know if the RC receivers have the right pulse width to Jaguars or Victors? Also does anyone have any experience with tamper proof screws/bolts? |
#19
Re: Outdoor Robot
I think that tamper-proof hardware isn't really appropriate unless you intend to be leaving the thing unattended for any length of time. |
#20
Re: Outdoor Robot
Do you have any links to a whitepaper or instructions to recalibrate the jags?
Thanks. |
#21
Re: Outdoor Robot
Re: Outdoor Robot
Thank You!
#23
Re: Outdoor Robot
This Major Qualifying Project at WPI was designed to inspect the thickness of the ice on frozen lakes for ice skaters.
They water proofed the robot by integrating a cavity inside the robot that is sealed when the robot is in operation. Its made out of Polycarb. and features a rubber ring around the interfacing pieces. All of the electronics are water tight and it might serve as "prior art" in your search. |
#24
Re: Outdoor Robot
To recalibrate, power up the Jag, hold down the USER button, then send the commands you want to be in the following order: full backward, full forward, then neutral. Release the USER button and wait for the LED to flash green, which indicates a good calibration. To reset to factory calibration, hold down the USER button, then power the Jag, release, and wait for the LED to flash. I don't remember the correct color pattern. |
#25
Re: Outdoor Robot
Thanks so much!
So will this allow them to work with vex controllers? |
#26
Re: Outdoor Robot
Vex controllers work fine; there's a robotics class at our school in which students develop a basic drivetrain and use Vex controllers (I'm not sure which type, though) to control Victors to drive the robot. I'm not too familiar with the code structure/commands, though I can't imagine it to be too complicated. |
#27
Re: Outdoor Robot
Thanks!
