Go to Post I'm a product of the 60's and react accordingly...I have an entire portion of my brain filled with song lyrics from the 60's and 70's which causes me to not have room for important stuff like motors, pneumatics, electrical system and green lights... - RoboMom [more]
Unread 17-05-2012, 16:18
tyandjel94 tyandjel94 is offline
FRC #1647 (Iron Devils)
tyandjel94 is an unknown quantity at this point
UDP Recieving Problems
We are trying to send information from a custom labview dashboard to the robot (runs java). We have a regular java applet that I can upload if you would like to see it, that works perfectly. When we try to enable the robot we get robots don't quit. Here is our code. Do you see any problems. Thanks.
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.*;
import java.io.IOException;
import javax.microedition.io.Connector;
import javax.microedition.io.Datagram;
import javax.microedition.io.DatagramConnection;
import javax.microedition.io.UDPDatagramConnection;
public class RobotTemplate extends SimpleRobot {
    double targX = 0.0;
    double targArea = 0.0;
    boolean aHasValue = false;
    boolean xHasValue = false;
    double distanceFromTarg = 0.0;
    static final double distanceConversionFactor = 0;
    static final int IMAGE_WIDTH = 320;
    int batman = 0;
    Datagram data;
    DatagramConnection receivePacket;
    String rawUdpData;
    Jaguar jagL1 = new Jaguar(3);
    Jaguar jagL2 = new Jaguar(4);
    Jaguar jagR1 = new Jaguar(1);
    Jaguar jagR2 = new Jaguar(2);
    Joystick stick3 = new Joystick(3);
    public void autonomous() {
    public void operatorControl() {
        while (isOperatorControl()) {
           udp();
            if (stick3.getRawButton(2)) {
                tracking();
            } else {
                jagL1.set(0.0);
                jagR1.set(0.0);
                jagL2.set(0.0);
                jagR2.set(0.0);
    public void udp() {
        try {
            receivePacket = (DatagramConnection)
                    Connector.open("data://:1130");
            // = new DatagramConnection(5021); //put port in here
            try{
                receivePacket.receive(data);
            }finally{
                receivePacket.close();
           //rawUdpData = data.readUTF();
           rawUdpData = (String.valueOf(data.getData()));
        } catch (IOException ex) {
            ex.printStackTrace();
        //  byte[] receiveData = new byte[1024]; //1024 is time out
        String udpArea = new String();
        String udpX = new String();
        //data recieving
        //DatagramPacket receivePacket = new DatagramPacket(receiveData, receiveData.length);
        // serverSocket.receive(receivePacket);
        //String rawUdpData = new String(receivePacket.getData());
        //  System.out.println("RECEIVED: " + rawUdpData);
        //string analizing
        if (rawUdpData.startsWith("Area: ")) { // 1 spaces
            //System.out.println("worked");
            udpArea = rawUdpData.replace('A', ' ');
            udpArea = udpArea.replace('r', ' ');
            udpArea = udpArea.replace('e', ' ');
            udpArea = udpArea.replace('a', ' ');
            udpArea = udpArea.replace(':', ' ');
            //  udpArea = (rawUdpData.replace("Area: ", ""));
            udpArea = udpArea.trim();
        if (rawUdpData.startsWith("Bounding X: ")) { // 1 spaces
            udpX = rawUdpData.replace('B', ' ');
            udpX = udpX.replace('o', ' ');
            udpX = udpX.replace('u', ' ');
            udpX = udpX.replace('n', ' ');
            udpX = udpX.replace('d', ' ');
            udpX = udpX.replace('i', ' ');
            udpX = udpX.replace('g', ' ');
            udpX = udpX.replace('X', ' ');
            udpX = udpX.replace(':', ' ');
            //   udpX = (rawUdpData.replace("Bounding X: ", "")); //removes lables
            udpX = udpX.trim(); //removes whitespace in string
        //safty for converting string to double
        if (udpArea.length() > 0) {
            aHasValue = true;
        } else {
            aHasValue = false;
            targArea = 0.0;
        if (udpX.length() > 0) {
            xHasValue = true;
        } else {
            xHasValue = false;
            targX = 0.0;
        //converts string to double
        if (aHasValue) {
            targArea = Double.parseDouble(udpArea);
        if (xHasValue) {
            targX = Double.parseDouble(udpX);
        System.out.println("Area string: " + udpArea);
        System.out.println("X string: " + udpX);
        System.out.println("a: " + targArea);
        System.out.println("X: " + targX);
    public void tracking() {
        if (xHasValue) {
            double distOffCenter = ((IMAGE_WIDTH / 2) - targX);
            double ratioOffCenter = distOffCenter / (IMAGE_WIDTH / 2);
            double speed = (0.3 * (ratioOffCenter * ratioOffCenter) + (distOffCenter > 0 ? 0.4 : -0.4)); //Left Right
            if ((Math.abs(speed)) <= 0.41 && batman <= 15) {
                batman++;
            if (Math.abs(speed) <= 0.41) {
                jagL1.set(0.0);
                jagL2.set(0.0);
                jagR1.set(0.0);
                jagR2.set(0.0);
            } else {
                jagL1.set(speed);
                jagL2.set(speed);
                jagR1.set(speed);
                jagR2.set(speed);
        } else {
            System.out.println("NOIMAGE");//Middle of target // myDrive.tankDrive(0, 0);
            jagL1.set(0.0);
            jagL2.set(0.0);
            jagR1.set(0.0);
            jagR2.set(0.0);
 //end of class
-Tyler
Team 1647 Iron Devils
Unread 20-05-2012, 00:33
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
Re: UDP Recieving Problems
This thread says that it's probably an uncaught exception somewhere. Are you getting any other information printing out? i.e. stack trace, etc.?
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 20-05-2012, 01:18
No. When we press enable it goes straight to robots don't quit. Do you see anything that isn't correctly coded for udp?
-Tyler
Unread 20-05-2012, 01:48
Would a possibility be a security exception?
-Tyler
Unread 20-05-2012, 15:16
Sunstroke Sunstroke is offline
Programmer
AKA: Joe Grinstead
FRC #3504 (Girls of Steel)
Sunstroke is an unknown quantity at this point
When it says "robots don't quit," it means that you are getting an exception. I believe it prints out the exception as well...
Unread 21-05-2012, 01:09
Fletch1373's Avatar
AKA: Fletch
Yes, that message is part of the library, not your code. It is supposed to print a stack trace with the actual error message immediately following the "robots don't quit" message.
Student:
Mentor:
Volunteer:
2016 Tour:
Unread 21-05-2012, 21:38
We have been getting the IO exception.
-Tyler
Unread 22-05-2012, 23:00
We aren't able to open the socket to the labview part can connect to it.
-Tyler
Unread 26-05-2012, 00:38
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Can you post the complete output of the console where you are getting the "Robots don't quit" message.
To help point you in the right direction in the mean time:
That message means there is an uncaught exception and it bubbled up to the system level. If it is an uncaught IO exception it should tell you a line number as well, but it probably has to do with your something within the udp() function.
Are you sure the parameter to connector.open is correct? I believe you should be using a "datagram" protocol instead of a "data" protocol.
For example
A datagram connection for accepting datagrams on port 1234
"datagram://:1234"
A datagram connection for sending to a server on port 1234:
"datagram://123.456.789.12:1234"
And it also looks like you never instantiate the Datagram variable "data", so its null when you call data.readUTF, and null when you use it as a param in receive(data). But that should throw a null point exception, and you should be seeing that in the console. If you don't that's because the program is failing before it gets to that line, which case your problem lies where you open your connection to the datagram (or maybe you do instantiate it somewhere and I just didn't notice it).
You mentioned that you have a java applet that works. Is that written using the same version of JavaME that is running on the cRIO? My guess is that you copied your code from the applet to the CRIO, however, if the code was written under different java environments it will not be able to run on the cRIO without modification.
Hope that helps.
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 28-05-2012, 20:00
ItzWarty ItzWarty is offline
FRC #1072 (Harker Robotics)
ItzWarty is an unknown quantity at this point
We had issues with networking in general. We used TCP for our robot-OI communication. I'd assume it's a bug on the FRC side, as opposed to yours - our code would work 3/4 of the time, and require a robot restart if it failed.
Leader of Team 1072. Software developer of RAF Manager.
Follow me on Twitter: Twitter.com/ItzWarty/
Unread 24-09-2012, 21:58
For example
"datagram://:1234"
Were you able to use the datagram protocol on the cRIO? I get the following exception: "javax.microedition.io.ConnectionNotFoundException : The 'datagram' protocol does not exist". The following thread says that datagram wasn't supported as of 2011: http://www.chiefdelphi.com/forums/sh...61&postcount=5
