Go to Post Dang! The 2008 game piece was supposed to be a secret. - dlavery [more]
Unread 11-01-2003, 09:58
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Re: Novice Question
Originally posted by dmellich
Being somewhat of a novice with motors/gears/transmissions I have a question. When doing the calculations to determine the correct reduction ratios to achieve a given speed, which rpm number do you start with - no load, normal load, @ max efficiency, or @ max power?
Also, is the "drill motor" everyone keeps talking about needing specs for the one that is in a small box with Bosch on it? Thanks in advance for any help.
When calculating the reduction, you should calculate the speed at free speed, because that's how fast your robot would go when driving around the field with no obstacle. Plan on losing 20% or so of free speed of your motors just because of friction inside the system.
Another way to approach the gearing is figure out how much torque you need to do certain tasks, such as going up the ramp. I mean, you can always gear however fast you want, but its useless if you don't have enough torque to go up the ramp. So, figure out the minimum torque that will get you up the ramp, and that will limit how fast you can go already. Try to gear it such that the amount of torque needed to go up the ramp is about half your stall torque.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
question on launching boxes 2PI4Julia Rules/Strategy 4 18-01-2003 10:17
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
