Go to Post There's a fine line between insanity and healthy obsesion with FIRST ... and sometimes I wonder which one I'm on - srawls [more]
Unread 26-05-2012, 16:21
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: On Board Computer
Originally Posted by daniel_dsouza View Post
I would be sold on using an on-board computer, if someone could solve the problem of turning off the robot.
This is the scenario. After the match ends, volunteers urge you to hurry off the field, and you push the main breaker, killing the power to the your Windows 7 PC.
I've always been told to not unplug a computer unless all else has failed. I've also seen devices (robot controllers, phones, tablets, computers) corrupt themselves when there was a loss of power. Would there be any damage to the computer (hardware failure, software corruption)? More importantly, is there anyway to safely shut the computer down before cutting the power?
Here's how I would do it...
Whenever the finish VI is called, send a UDP packet to the PC that has a command to tell the PC to shutdown (gracefully). I already have it working actually.
Since I'm using LabVIEW, I have it set to call the command line function "shutdown -s -t 5" which gives LabVIEW a few seconds to end gracefully. Right after this call, I have a Quit function which will suspend all of LabVIEW, then will shut down the PC normally. By keeping the system cleaned and optimized (with SSD and i7 nonetheless), it only takes a matter of seconds to shutdown, plenty of time for you to casually walk to your robot on the field and shut it down.
There is also a choice of using the NI Real Time Operating System, which I believe our license has access to. It's designed to be able to turn off immediately if needed. It just runs a single program from the disk. The only faults would be if you're reading and writing data to the HD.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 26-05-2012, 19:16
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Does the finish VI actually get called at the end of a real match? I was under the impression that it just returned to the teleop disabled vi. Please correct me if I'm wrong.
Unread 27-05-2012, 05:32
RyanN's Avatar
RyanN
Hmm... good point. I think you're correct. The Finish VI is only called when you push the Finish button on the Robot Main VI, isn't it...
Well back to the drawing board...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 27-05-2012, 19:11
John's Avatar
AKA: John Gillespie
This year, my team had lights on our robot, that we wanted to do something specific at the end of the match. I believe we put the command in Disabled, and added some logic to only use the command on the third time disabled is called (once at beginning of match, once after auto, once at the end).
Unread 28-05-2012, 02:31
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
I'm not an LV programmer but I have had to work with it a little for FRC. I would put a variable in called something like teleopRan and initialize it to False. Then when teleop starts you can set it to True, then when Teleop Disabled is run have a if that checks if teleopRan is true and match time is greater than say... 119 seconds (so if it disconnects on the field it doesn't turn off the computer in case it reconnects) then shut off the computer. You'll want to test this with practice mode obviously.
- Oliver
