Go to Post I think that's what they think you will think, therefore you are thinking what they want you to think. - Wetzel [more]
Unread 26-05-2012, 19:16
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Re: On Board Computer
Originally Posted by RyanN View Post
Whenever the finish VI is called
Does the finish VI actually get called at the end of a real match? I was under the impression that it just returned to the teleop disabled vi. Please correct me if I'm wrong.
Unread 27-05-2012, 05:32
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Hmm... good point. I think you're correct. The Finish VI is only called when you push the Finish button on the Robot Main VI, isn't it...
Well back to the drawing board...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 27-05-2012, 19:11
John's Avatar
AKA: John Gillespie
This year, my team had lights on our robot, that we wanted to do something specific at the end of the match. I believe we put the command in Disabled, and added some logic to only use the command on the third time disabled is called (once at beginning of match, once after auto, once at the end).
Unread 28-05-2012, 02:31
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
I'm not an LV programmer but I have had to work with it a little for FRC. I would put a variable in called something like teleopRan and initialize it to False. Then when teleop starts you can set it to True, then when Teleop Disabled is run have a if that checks if teleopRan is true and match time is greater than say... 119 seconds (so if it disconnects on the field it doesn't turn off the computer in case it reconnects) then shut off the computer. You'll want to test this with practice mode obviously.
- Oliver
