Go to Post Ironically, I think the best testament to the program [Dean Kamen] founded and his ideals wouldn't be if he won a Nobel Prize. It would be if you did. - Kevin Sevcik [more]
Unread 21-01-2012, 14:42
ForeverFBI ForeverFBI is offline
FRC #1723
ForeverFBI is an unknown quantity at this point
Kinect installation issue
we installed all the correct the software for the Kinect, but when we try to run skeletal viewer it crashes on start-up. the error that it states is: "The application was unable to start correctly (0xc000007b). Click OK to close the application."
any help?
Unread 27-05-2012, 15:44
palle palle is offline
palle is an unknown quantity at this point
Re: Kinect installation issue
sound like you have a directx problem.
http://pcsupport.about.com/od/findby...sing-error.htm
i hope it helpet
Unread 28-05-2012, 14:45
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Also make sure you have the correct kinect sdk.
At the time of competition, the kinect server required "Microsoft Kinect 1.0 Beta2 SDK". However the latest version is 1.5. I believe that our team had installed the wrong version at first...
It looks like the installer hasn't been updated since January, so you probably use the Beta2 SDK. Available here.
For more information, look here.
Hope this helps.
