Go to Post Pompous boasts dont get you anywhere. Results get your name on the book... - Jeremy_Mc [more]
Unread 29-05-2012, 17:17
Fritz3081 Fritz3081 is offline
FRC #3081
Fritz3081 is an unknown quantity at this point
Re: Joysticks
Are team uses a Logitech attack 3 put into a radio shack project box. It works well for an actuator joystick.
Unread 29-05-2012, 17:21
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Joysticks
Generally my students have just used a USB game pad, ours happens to be an xbox controller, whenever they have needed a collection of buttons without the joystick for the operator.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 29-05-2012, 18:25
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Re: Joysticks
Logitech extreme 3d pro has 6 buttons on the side, throttle, 4 buttons on the stick, hat switch, trigger and side button, and a twist stick.
Basically the KOP joystick but better...
But it's height is 7 3/4 inches
Unread 29-05-2012, 20:12
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Joysticks
That is the KOP Joystick?
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 29-05-2012, 20:37
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Re: Joysticks
No, it isn't. The KOP joystick is a Logitech Attack 3, this is an Extreme 3.
While similar, the Extreme 3 has an extra button and a mini-joystick (I don't know the correct term) on the top. Plus this has a twist stick, the KOP one does not.
Hope this helps!
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 30-05-2012, 00:33
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Joysticks
Its usually referred to as a hat switch or something like that, I just call it a hat.
Unread 30-05-2012, 01:34
JonathanZur1836 JonathanZur1836 is offline
FRC #1836 (The Milken Knights)
JonathanZur1836 has a spectacular aura aboutJonathanZur1836 has a spectacular aura about
Re: Joysticks
Our team has used Logitech Attack 2's in the past, and they have been rather reliable and very applicable. This year, one of our drivers used an x-box controller to control the drivetrain and the other driver used an attack 2 to control ball intake, elevator, & shooter. In my opinion, the factors that influence what controller you go with should be the game itself, and driver preferences.
[size="2"][b][font="Tahoma"]Team 1836 - MilkenKnights
Unread 30-05-2012, 10:16
Re: Joysticks
Hope this helps!
Ah, I see, our team never uses the KOP joysticks, we get the Extreme 3Ds and store them with the KOP stuff.
Unread 30-05-2012, 10:44
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Joysticks
Having driven with a few types of joysticks and gamepads, the Logitech Attack 3's are my least favorite by far.
Over the past 3 years, we've used:
-Logitech DualAction gamepad (all three years)
-Logitech F310 or Xbox (identical functionally, F310 is better to me, two years)
-Custom Cypress-based box (never will use Cypress board again)
-Custom box based on Logitech Precision (no analog inputs, otherwise very good)
-Custom box based on uHID (very very good, would use uHID again)
I personally prefer the (very old) CH Flightsticks in terms of actual joysticks, as I like the spring feel much more than that of the Attack 3.
I would highly recommend the Logitech Dual Action and F310 gamepads, as well as the uHID, to any team.
Kettering Motorsports
Unread 30-05-2012, 10:58
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: Joysticks
Andrew,
Is there anything special one has to do to use the Logitech DualAction gamepad with the base FRC Labview software?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 30-05-2012, 11:49
apalrd's Avatar
More Torque!
VRC #3333
Re: Joysticks
No.
Left stick shows up as axis 1 and 2 (X and Y respectively), right stick shows up as axis 3 and 4 (x and y again), and D-pad shows up as axis 5 and 6 (it's binary, so it will be either 0, +1, or -1 for each axis).
All of the buttons are numbered on the joystick, and correspond to the same number in software. L3 and R3 (pressing the joysticks) are buttons 11 and 12, they are not labeled on the joystick. I attached a pair of LabVIEW controls for the mapping of the buttons and axis, if you cast the LabVIEW Joystick Get clusters to these two controls, it will name all of the buttons correctly.
The F310 and 360 have identical button/axis mappings. See attached 360 files. Please note that L2 and R2 (buttons 9 and 10) are actually unused, I have some code that gets a digital output from the analog triggers (axis 3 is the raw trigger data fro L2 and R2).
(I had to zip them as CD does not allow uploading of .ctl files).
Unread 02-06-2012, 01:58
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Joysticks
We took the KOP joysticks and unscrewed the two halves of the actual stick portion and unplugged the wires from the PCB, tucked the end of the cable into the stub-stick that remained, and wrapped it with rubber tape. it takes a bit more force to actuate as a result of the shorter lever, but it is much shorter, also, the cable could be attached to a custom button array either on-stick or off by simply replicating the circuitry of the original PCB, or at least the parts you need.
Unread 02-06-2012, 11:51
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
Re: Joysticks
I've been using the Cyborg for a few years now:
http://www.amazon.com/Saitek-Cyborg-.../dp/B001EYU1VO
the WPILib joystick don't let you use all of the buttons, but if you write some custom objects/dashboard you get full functionality. it has more buttons than you'll ever really need, and its fully customizable
WPI Robotics Engineering & Mechanical Engineering Class of 15
iRobot Mechanical Engineering Intern
Unread 29-05-2012, 22:39
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: Joysticks
It depends what you're looking for when you say better. Attack 3 has way more buttons than I need anyway, so the smaller footprint and lower cost is better for our uses.
