Go to Post A team isn't who funds it. A team is the people who are on it -Kelli - KelliV [more]
Unread 29-05-2012, 10:25
ABA's Avatar
ABA ABA is offline
FRC #1153
ABA is an unknown quantity at this point
Joysticks
does anyone use a joystick with a fair amount of buttons on it, that is shorter than 7" tall
Unread 29-05-2012, 10:27
ABA's Avatar
ABA ABA is offline
FRC #1153
Re: Joysticks
less than 7" in any direction*, length, width, or height
Unread 29-05-2012, 10:50
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: Joysticks
Instead of posting twice you can always click edit in the lower right corner of your post
But how many buttons do you need, minimum?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 29-05-2012, 11:01
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Joysticks
I donated my Microsoft Sidewinder Precision 2 to the team for use as the OP stick. Its got 4 axis (X,Y, and a Z that you twist the stick for, and a throttle), something like 10 buttons, and a hat.
You can really just use any usb joystick..
EDIT: Okay, 8 buttons.
Unread 29-05-2012, 13:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Joysticks
A USB gamepad such as the Logitec has two little joysticks, and a bunch of buttons....and they're very compact. Try it you'll like it.
Unread 29-05-2012, 15:11
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Joysticks
If you just need the buttons you could always try ESTOP's I/O module and make your own button board.
Dont forget you can use more then 2 USB inputs, and so youd still have both joysticks, but with an added bonus of an easy to use, custom buton board.
Unread 29-05-2012, 17:17
Fritz3081 Fritz3081 is offline
FRC #3081
Fritz3081 is an unknown quantity at this point
Re: Joysticks
Are team uses a Logitech attack 3 put into a radio shack project box. It works well for an actuator joystick.
Unread 29-05-2012, 17:21
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Joysticks
Generally my students have just used a USB game pad, ours happens to be an xbox controller, whenever they have needed a collection of buttons without the joystick for the operator.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 29-05-2012, 18:25
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Re: Joysticks
Logitech extreme 3d pro has 6 buttons on the side, throttle, 4 buttons on the stick, hat switch, trigger and side button, and a twist stick.
Basically the KOP joystick but better...
But it's height is 7 3/4 inches
Unread 29-05-2012, 20:12
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Re: Joysticks
That is the KOP Joystick?
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 29-05-2012, 20:37
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Re: Joysticks
No, it isn't. The KOP joystick is a Logitech Attack 3, this is an Extreme 3.
While similar, the Extreme 3 has an extra button and a mini-joystick (I don't know the correct term) on the top. Plus this has a twist stick, the KOP one does not.
Hope this helps!
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 29-05-2012, 22:39
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: Joysticks
It depends what you're looking for when you say better. Attack 3 has way more buttons than I need anyway, so the smaller footprint and lower cost is better for our uses.
Unread 30-05-2012, 00:33
AKA: Brandon Liatys
Re: Joysticks
Its usually referred to as a hat switch or something like that, I just call it a hat.
Unread 30-05-2012, 01:34
JonathanZur1836 JonathanZur1836 is offline
FRC #1836 (The Milken Knights)
JonathanZur1836 has a spectacular aura aboutJonathanZur1836 has a spectacular aura about
Re: Joysticks
Our team has used Logitech Attack 2's in the past, and they have been rather reliable and very applicable. This year, one of our drivers used an x-box controller to control the drivetrain and the other driver used an attack 2 to control ball intake, elevator, & shooter. In my opinion, the factors that influence what controller you go with should be the game itself, and driver preferences.
[size="2"][b][font="Tahoma"]Team 1836 - MilkenKnights
Unread 30-05-2012, 10:16
Re: Joysticks
Hope this helps!
Ah, I see, our team never uses the KOP joysticks, we get the Extreme 3Ds and store them with the KOP stuff.
