| Thread Tools |
Rating:
Display Modes |
CAN Commands Formats & Documentation
Does anyone know if or where the CAN commands that are used in FRC are documented?
I'm planning on doing some prototyping with an Ardunio and CAN Shield, with the FRC Jaguars. If anyone can point me to the formats, structure, documentation that be great. Thanks. |
Re: CAN Commands Formats & Documentation
You probably ought to get in contact with the "Cross the Road" folks. They do CAN in a big way, and probably know what they're doing...
If you aren't using the FRC control system, you would probably be better off using the non-FRC Jaguar firmware. Its documentation is as complete as it gets -- the source code is freely available.
![]() Quote:
As for the firmware, I'm going to try to work with the FRC version as I'm very curious as to it's innards(firmware) and how it responds. Whether or not I'm successful using the FRC doesn't really matter it's part of my plan to see what I can get if anything. I can swap firmware easy enough to run comparison tests. Thanks again, everyone. |
-Joe |
