Go to Post From what I've seen in FIRST, teams that copy generally always learn something from it, and if they don't, the copy they produce is of much lower quality than the original. - TheOtherGuy [more]
Unread 30-05-2012, 10:44
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Joysticks
Having driven with a few types of joysticks and gamepads, the Logitech Attack 3's are my least favorite by far.
Over the past 3 years, we've used:
-Logitech DualAction gamepad (all three years)
-Logitech F310 or Xbox (identical functionally, F310 is better to me, two years)
-Custom Cypress-based box (never will use Cypress board again)
-Custom box based on Logitech Precision (no analog inputs, otherwise very good)
-Custom box based on uHID (very very good, would use uHID again)
I personally prefer the (very old) CH Flightsticks in terms of actual joysticks, as I like the spring feel much more than that of the Attack 3.
I would highly recommend the Logitech Dual Action and F310 gamepads, as well as the uHID, to any team.
Kettering Motorsports
Unread 30-05-2012, 10:58
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: Joysticks
Andrew,
Is there anything special one has to do to use the Logitech DualAction gamepad with the base FRC Labview software?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 30-05-2012, 11:49
apalrd's Avatar
More Torque!
VRC #3333
Re: Joysticks
No.
Left stick shows up as axis 1 and 2 (X and Y respectively), right stick shows up as axis 3 and 4 (x and y again), and D-pad shows up as axis 5 and 6 (it's binary, so it will be either 0, +1, or -1 for each axis).
All of the buttons are numbered on the joystick, and correspond to the same number in software. L3 and R3 (pressing the joysticks) are buttons 11 and 12, they are not labeled on the joystick. I attached a pair of LabVIEW controls for the mapping of the buttons and axis, if you cast the LabVIEW Joystick Get clusters to these two controls, it will name all of the buttons correctly.
The F310 and 360 have identical button/axis mappings. See attached 360 files. Please note that L2 and R2 (buttons 9 and 10) are actually unused, I have some code that gets a digital output from the analog triggers (axis 3 is the raw trigger data fro L2 and R2).
(I had to zip them as CD does not allow uploading of .ctl files).
Unread 02-06-2012, 01:58
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Joysticks
We took the KOP joysticks and unscrewed the two halves of the actual stick portion and unplugged the wires from the PCB, tucked the end of the cable into the stub-stick that remained, and wrapped it with rubber tape. it takes a bit more force to actuate as a result of the shorter lever, but it is much shorter, also, the cable could be attached to a custom button array either on-stick or off by simply replicating the circuitry of the original PCB, or at least the parts you need.
Unread 02-06-2012, 11:51
BEEKMAN BEEKMAN is offline
AKA: Brendan McLeod
FRC #0190 (Gompei and the Herd)
BEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to beholdBEEKMAN is a splendid one to behold
Re: Joysticks
I've been using the Cyborg for a few years now:
http://www.amazon.com/Saitek-Cyborg-.../dp/B001EYU1VO
the WPILib joystick don't let you use all of the buttons, but if you write some custom objects/dashboard you get full functionality. it has more buttons than you'll ever really need, and its fully customizable
WPI Robotics Engineering & Mechanical Engineering Class of 15
iRobot Mechanical Engineering Intern
