#16
Re: How to use igus chain.
Maybe a quantum transport mechanism? :0 The heat gun required to reassemble the ball didn't get by tech inspection.
We attached our wire bundle on the outboard edge of the turret & high on the support frame: allowing a loop to hang down. We used spiral wrap to keep it compact & made sure there was no perturbations on the robot for it to hang on. We easily got +- 180 degrees. |
#17
I actually was actually unsure of how my theory would work until I realized a fixed point above the center of rotation would do the trick.
#18
Igus actually offers several non-linear products that may be beneficial for the application. The following links will take you to a couple of them.
http://www.igus.de/wpck/default.aspx...tband&CL=DE-en http://www.igus.de/wpck/default.aspx...7085&C=DE&L=en http://www.igus.de/wpck/default.aspx...2899&C=DE&L=en |
