Go to Post Win, Lose or Tie, but do it in a way that FIRSTers will be talking about for years to come! - Bill Moore [more]
Unread 31-05-2012, 12:29
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
pic: Robot cart design
Unread 31-05-2012, 12:31
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: pic: Robot cart design
Are the pans meant to hold the wheels?
Unread 31-05-2012, 12:44
Originally Posted by Camren View Post
A robot cart that allows a fail safe way to elevate the bot and work under it,...
What do you mean by "fail safe"? I don't think I understand how the design is supposed to work.
Unread 31-05-2012, 12:49
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
It looks like you manually lift it and it locks in place. I cannot tell though. Also, would this cart be used for just one year, because if the robot specs change this cart might be useless.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 31-05-2012, 13:27
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
If you were to make an entire tray instead of the 2 small railings, you would be able to use it for a robot in any configuration. You lose the ability to work on the middle section easy...but I think its a good tradeoff.
maybe make an "open box" shape so if you have a wide robot or something your cart doesnt become obselete?
yours current:
my suggestion
Mr. Mike's Avatar
Mr. Mike Mr. Mike is offline
FRC #3138 (Innovators)
Mr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to all
Camren
You have a good start. Remember that the robots change from year to year so add some adjustability to your design. Add some mounting holes where the robots sets. This way you can add features that will support the robot on its frame rather than setting it on its wheels. (You will want to run the drive train in the pits) Watch the minimum over lap in the legs. (This could be s safety issue) Have fixed wheels on one end and casters on the other. (A cart with 4 casters is very hard to move through a crowd) Keep up the good work and post often.
Unread 31-05-2012, 13:49
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Camren just don't use casters like we have on our battery box You guys have no idea how many times those have broken. Are you still planning on building a new battery box for next year?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 31-05-2012, 13:53
It's possible to have the rails, but make them adjustable so they can fit multiple robots over the years. 330's done that for years.
I'm a tad bit concerned over the lack of support up high. What I mean by that is, what's keeping the rails from bending, either away from each other or towards each other, or in unison to one side or the other? Also, what's the moment like if someone jostles the robot while it's being moved? (Read: if the robot is at max height, in motion or not, what's it going to take to knock it over, cart and all?)
Unread 31-05-2012, 14:09
You would really benefit from some gussets at the bottom to help support the large load you are going to have.
Unread 31-05-2012, 14:14
qzrrbz qzrrbz is offline
FRC #0469
qzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to behold
Make sure that "normal" height of cart plus robot can get through a school door such as they have at IRI. Won't mention the team(s) that have had issues with that!
Unread 31-05-2012, 14:34
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
It doesn't look like you'll have an issue with weight or anything of the sort, but also take into consideration how you're moving the cart. Not like the pneumatic AM castors you're making, but transporting the entire cart (with or without robot) to competitions (ie. van, bus, truck, trailer), and how you're getting it into the vehicle.
Also, after long periods of queing times, have any teams ever thought about putting in foldout seats? XD
Academic Student (Forever)
Unread 31-05-2012, 15:39
Camren's Avatar
Yes the wheels go into the pans which are only an inch tall
Unread 31-05-2012, 15:47
Camren's Avatar
5 pieces 2 sides 2 middle bars and the cushioned laying pad for working on the bottom. Transporting was a big constraint while designing
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
Actually, we have our newest cart setup with a main sofa-like seat and soon to come fold-able side seats. Also, it will be motorized and will be couch
We make easy things look difficult, everyday!
Unread 31-05-2012, 16:29
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
You really should stay away from supporting a robot by it's wheels while on a cart or in the pits. Controls will probably want to run the transmissions to test the robot, and if it's resting on the wheels that's a bear. In addition, if someone accidentally hits the controls while the robot is on and enabled, it's going to drive off the cart and hurt someone. See if you can plan on supporting the robot by its frame.
