Go to Post Students learn from, are inspired by, and emulate their mentors. A team with a solid mentor base helps to create a productive, inspired, and ultimately successful group of students. - Jared Russell [more]
Unread 31-05-2012, 21:04
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
Auto body Stand Robot cart
Has anyone thought about placing a bracket on your bot so it can be supported by a engine stand or full car body stand. Like
In thought It wouldn't be a bad idea. You could rotate your bot easily and its used to support heavy loads. The only problem it the support on an engine stand is for a more compact object and a body stand would be to big for you pit or to bring into the pits.
Unread 31-05-2012, 21:22
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: Auto body Stand Robot cart
It's an interesting thought, but it is something that you have to design a robot around. The robot has to attach to the stand using bolts on a vertical plane. This year this would have been easy, the game lent itself to "tower bots". The game changes every year and future designs may not be conducive to this type of mounting system.
The other problem that I see is lifting a robot to the hight of the engine stand to mount it.
That being said, the ability to easily move a robot and rotate it to work at any angle would be amazing. If you could design something from the ground up to do this safely it would make work a lot easier.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 01-06-2012, 07:08
Camren's Avatar
What about one that is made to bolt onto the KOP Andymark C Channel
