Go to Post Nothing's more memorable than giving someone a foul mouthed clown :cool: - Dave Scheck [more]
Unread 31-05-2012, 17:47
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
Re: pic: Robot cart design
a suggestion:
make the bottom be set up in some way so the sides can move in and out with enough range that you will always be able to fit the robot frame to that (the width of an industry standard door or just smaller would be a good idea) then have the top "rails" be set with holes and have pins that slide into the holes and stop at a certain height. That way, you can have it resting on the wheels if u need to and on the frame when u need to. If you do it right, new pins could be made in a madder of minutes on a lathe if you need taller or shorter.
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 31-05-2012, 19:11
iyermihir iyermihir is offline
FRC #0649 (Saratoga MSET)
Team Role: CAD
iyermihir has a spectacular aura aboutiyermihir has a spectacular aura about
Originally Posted by Tom Line View Post
You really should stay away from supporting a robot by it's wheels while on a cart or in the pits. Controls will probably want to run the transmissions to test the robot, and if it's resting on the wheels that's a bear. In addition, if someone accidentally hits the controls while the robot is on and enabled, it's going to drive off the cart and hurt someone. See if you can plan on supporting the robot by its frame.
This can be very useful. I designed a cart last fall that my team used for this years FRC season, and the programmers were quite happy about this. It let us troubleshoot problems at a regional and gave us a way to test code involving driving without the danger of a moving robot. Another thing to consider is the wheels. I chose 8in pneumatic wheels for mine which worked very well. I bought them from grainger and you might want to consider this as an alternative to making your own casters. Also, to ensure that the cart could be used for many years, it is made out of extrusion which makes it easy to change the wheel positions for future robots. Ill try to post some pictures soon. Also, make sure that a five foot tall robot can be taken through a standard doorway on the cart, it makes life a lot easier.
Unread 31-05-2012, 20:50
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
Thanks for all the support guys
Planning on making a better autodesk design this weekend. I kind of half way did this one (anyone notice the pan legs weren't matched with the base). Some additions I am planning are:
-More support for limbs
-Width and Height constraints (I'm pretty sure the setup i have now fits height but I have not check and bumpers are always a burden when going through doorways.)
-Pan feet for frame support
- A bumper holder that attaches to the bottom. (right now their is just a cushioned board for working on the underbelly
- Fold out seat
- Fan Bracket (Pits, Que and Arena are very hot)
Also in my new sketch I will add color and more views. Ill try and make a portfolio including some good views, annotation and animation
Unread 31-05-2012, 20:56
gracie.'s Avatar
gracie. gracie. is offline
forgot the heat shrink...
FRC #2399 (The Fighting Unicorns)
gracie. is an unknown quantity at this point
what are you thinking of making this out of?
2399: The Fighting Unicorns! - Alumna, team sister | Dean's List Finalist 2013
Anyone need a mentor in west LA?
Unread 31-05-2012, 21:15
Camren's Avatar
Preferably aluminum but i'm unsure how it will handle the abuse so possibly steel.
Unread 31-05-2012, 22:38
Peck's Avatar
if aluminum can't take the abuse of being a robot cart, you should take another look at your design. Steel will, in all likelihood, hurt more then it will help.
For example (over engineering it): If your robot weighs 200 lbs and you have 4 support beams holding that weight, then each beam will receive (ideally) 50 lbs. Basic mechanical physics tells use that the beams will be receiving a compression from the weight. Go to your school (or local) lifting room and put a 50 lbs weight (or 50 lbs equivalency) on the top of some aluminum of about the dimensions you want to have for your support beam. If it notices the weight at all then beef it up.
TEAM 1619
Unread 01-06-2012, 05:45
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Most aluminum isn't that weak. Do take careful note of which alloy you use, because depending on the abuse your cart takes, that will make a difference.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 01-06-2012, 13:24
howyadugan1730's Avatar
howyadugan1730 howyadugan1730 is offline
AKA: Matthew Dugan
FRC #1730 (Team Driven)
howyadugan1730 is an unknown quantity at this point
i would suggest adding some wheels before doing anything else
Unread 01-06-2012, 15:29
Camren's Avatar
I was thinking of old fashion emperor style transport. 4 rookies on each corner.
Unread 01-06-2012, 15:57
Peck's Avatar
I don't think the field volunteers would be happy about a "cart" involving 16 rookies (though i'm sure software would love it).
TEAM 1619
