Go to Post Besides, all the FIRSTers that I know - are children at heart. - JaneYoung [more]
Unread 31-05-2012, 22:25
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
ArrayList on CRIO
The java.utils.ArrayList library is not available in the libraries given by default in the netbeans plugin for FRC. Is this for a good reason (Compatibility?)?
What are comparable libraries available that can be used on the CRIO? (Obviously not ON the CRIO, but I think you understand what I mean). The Vector class is depreciated now, but I think that is my best bet.
Any advice?
All opinions are my own.
Unread 31-05-2012, 22:40
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
Re: ArrayList on CRIO
Just use Vector. I know it's deprecated, but that's all you have to work with unfortunately. You're going to have to add a cast when you use get(), because Java ME doesn't support generics.
Unread 31-05-2012, 22:46
AKA: Joel Gallant
Thanks for the advice
Unread 31-05-2012, 23:49
vinnie's Avatar
Good luck! I think I will be switching to C++ next year as I keep getting really frustrated with the Java ME that we have on the cRIO.
Unread 31-05-2012, 23:51
AKA: Joel Gallant
It is a pain making awesome programs ported to SE, and having to find out that the libraries just arn't there.
Unread 01-06-2012, 02:46
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
We dropped C++ about 3 days before bagging ( ) and switched to java because it was an easier development environment to work with. Neither one is perfect, test it first to make sure you really want to switch.
