Go to Post Maybe it's the guy who doesn't stop drawing in his notebook in class, or the girl who writes the best essays in English. What team can't use their skills? - KathieK [more]
Unread 02-06-2012, 15:49
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
West Coast Drive: Output "shifting" shaft
I am currently in the midst of designing a 2 Speed Dog Shifting Gearbox. My question is regarding the elipse cutout for the dog gear to slide. As seen here, 254 uses a center distance of .49", which makes sense. It seems to me because they are using a 1/2" Stroke Piston. One question that arises is, "Why do they make it .49" instead of .5"?
But my real question is with regards to 973's output shaft. Instead of using a center distance of somewhere around .5", they have a center distance of .39. Why would they use that center distance, if the stroke is 1/2 an inch?
Wouldn't that cause some sort of jamming?
Thanks,
Adam
DISCLAIMER: I do not have much experience with Pneumatics, so I'll leave it up to the CD community for answers.
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
Unread 02-06-2012, 16:08
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: West Coast Drive: Output "shifting" shaft
Thanks,
Adam
We use a 1/2" stroke piston because they are easier to get a hold of and do not require stroke limiting spacers. We have used ~.375" spacing before, but did not like having to account for the spacer and did not want to order a shorter stroke custom cylinder.
I am not sure why you see a .49" spacing. It should actually be larger than 1/2" to account for tolerence stack up and to give the dog some room to disengage before engaging in the other dogged gear.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 02-06-2012, 16:50
Design Mentor
Alright, so I understand that if we do not want to use a stroke limiting spacer, the center distance should be >1/2". How much greater? And would it be possible to simply keep the spacing at 1/2"? The width of the teeth on the dog is .45", so wouldn't that allow the dog to fully disengage between strokes?
Unread 02-06-2012, 21:20
AdamHeard's Avatar
Lead Mentor
As Travis touched on, we mechanically limit the motion of the shifting action by limiting how far the external shift block can move (the block threaded onto the cylinder that interfaces to the small internal shaft via bearings).
I have a personal obsession with trying to make things smaller, and doing this allows us to shave the maximum amount of length off the gearbox by reducing the space between the gears (where the dog is), and minimizing how much the cylinder sticks out in the rear.
Unread 02-06-2012, 22:36
Design Mentor
I have very little experience with pneumatics, so this may be a fairly trivial question. But, from what I gather, when the piston is extended (or retracted) and hits a gear before it completely extends or retracts, the piston will remain locked into that position.
Adam. If the center distance is shorter than the stroke length, will a problem arise of the system jamming or the free spinning dog gears being pushed out of place?
What engineering thought should go into the dimension for those center distances?
Unread 03-06-2012, 00:18
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The system won't jam but you will greatly increase your odds of shearing the pin that links the dog to the shifter shaft.
2001-2004: Team 100
2006-Present: Team 254
Unread 03-06-2012, 00:42
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
DO NOT SHEAR THAT PIN! they suck to get back in, or get one out (especially if it snapped inside). unless you have a tool to do it (we dont), and i have no idea if there even is a tool.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 03-06-2012, 01:51
Design Mentor
Since I'm just entering into Mechanical Engineering as an Undergraduate next year at UCLA, I am unfamiliar with the engineering principles and guiding formulas to test shear stress applied at certain conditions, and the shear stress that a screw (I'm thinking #4-40) will withstand before succumbing to failure.
Can anybody please enlighten me, or is this not worth calculating?
Unread 03-06-2012, 02:54
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
screws don't like shear, also, 4-40 is rather small, the amount of shear force the cylinder would apply would be equal to the force the cylinder applies (as in all of the load applied to the screw by the cylinder are shear forces) so that would be (one half of the bore) squared times pi times the system gauge pressure
there may be some additional forces on the screw from the transmission itself, but the shaft should take most of this so it should be negligible.
NOTE: I believe in 2010 AM tried using screws in their shifters and found that they broke a lot more often then pins did.
Unread 03-06-2012, 04:06
Design Mentor
Ahhh, yes, this is just simple physics. I was over thinking the problem.
Thanks
