Go to Post Dedicated students inspire parents and mentors, dedicated mentors inspire students. - Akash Rastogi [more]
Unread 02-06-2012, 16:31
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
AM Shifter Question
Would there be any problem with removing the high gear in an AM Shifter? It would be used to quickly engage and disengage the drive motor. Has anyone done this before?
I have not had access to our room to look at them and will not for some time so I figured I'd ask you guys.
We make easy things look difficult, everyday!
Unread 02-06-2012, 16:45
wilful's Avatar
wilful wilful is offline
766 Alum & 4212 Mentor
FRC #4212 (TechnoFerrets)
wilful will become famous soon enough
Re: AM Shifter Question
not entirely sure on your reasoning for wanting to be able to shift into neutral, but I do know that as is, the AM shifters have a bit of a neutral zone already. so if you spent the time you could use servos to shift and figure out the neutral position
Wilful
2009-2013 Student, FRC 766
2013-Present College Student and Mentor, FRC 4212
Unread 02-06-2012, 17:04
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
We experimented with it for our kicker in Breakaway to load a spring and it worked well. We didn't use during the season but not because it didn't work.
Unread 02-06-2012, 17:30
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
My former team, 1747, tried that for a 2010kicker as well, using a window motor... it was a spectacular failure, as it took 300lbs of force to disengage the dog. we then tried beveling the dogs, which wouldn't stay in gear. We ultimatly used this to engage and disengage the motor. Unlike other parts of that bot, The transmission worked well.
Unread 02-06-2012, 21:00
1502's Avatar
AKA: Ryan G
They will be used for our cart to allow us switch between driving it and pushing it basically on the fly. We're using the pneumatic shifting method as we will have other pneumatic features on our cart. (it has mecanums)
Unread 02-06-2012, 21:40
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Octocanum Please octocanum.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 02-06-2012, 21:43
mikemat mikemat is offline
mikemat has a spectacular aura aboutmikemat has a spectacular aura aboutmikemat has a spectacular aura about
For that, it should work fine. You could have a problem with using pneumatics because the system may not always be pressurized. Servos might work better because they would allow you to shift regardless of air pressure in the system, and shifting at seed will not be an issue. Just curious, will there be 2 cims per wheel? Because that would be pretty cool.
1502's Avatar
AKA: Ryan G
It's a possibility
Mike: The system will be pressurized when it's in use so that shouldn't be an issue. I'm not sure what parts we will have but whatever we have a full (or closest) set of we'll probably ending up using. We are good with servos, but our team seems to struggle with pneumatic's though so I'm pushing it.
Unread 02-06-2012, 21:47
Gregor's Avatar
It's a possibility
Please come to a GTR event. I want to see this.
<Since 2011
Unread 03-06-2012, 01:07
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
It's a possibility
Consider using spring return cylinders. That way, when you lose pneumatics, the cylinders will automatically shift into neutral.
We have done the same when we wanted a transmission to shift into neutral. We tried it in 2010, but found we didn't like the drag on the kicker (the kicker had to spin the shaft to unroll our winch line).
Unread 03-06-2012, 13:22
Seconding the spring returns. I think you may be annoyed if you take the cart off the trailer and have to find a battery, boot the cart, and let it pressurize just to disengage the wheels (or you could disengage all 4 by hand, which probably involves sending someone under the cart) so you can get out of the 30 degree Michigan winter.
Unread 04-06-2012, 11:02
1502's Avatar
AKA: Ryan G
Yes, we're planning on using spring return mainly for safety. That way if something bad happens and we would have to cut power we could still move it or if there is a malfunction in the drive we could disengage the motor with a kill switch that would be on its own circuit.
Unread 04-06-2012, 21:26
Brian Ha's Avatar
Brian Ha Brian Ha is offline
Teh Ha Kid
FRC #0302 (Team 302)
Team Role: Driver
Brian Ha has a spectacular aura aboutBrian Ha has a spectacular aura aboutBrian Ha has a spectacular aura about
We actually wanted to try this for this year's competition. We thought that having a neutral might be advantageous when balancing to allow our alliance partner to just push us up. We unfortunately decided to stay with all gears and didn't make a neutral. Although i would love to see how this turns out to see if it works (I don't see any reason why it wouldn't)
Starcraft 2 Hit me up Cheese 972, or join the FRC chat room ingame
Unread 05-06-2012, 13:43
1502's Avatar
AKA: Ryan G
Shall do. As soon as it's done and all. I know CD would probably be interested in seeing the final project
(Should be done and have pictures (maybe even a video) on here sometime before next build season LOL)
Unread 05-06-2012, 23:48
1502's Avatar
AKA: Ryan G
Another question: does anyone know how much force a spring return cylinder for this shifter has when pressure is released?
