Go to Post "Trying to teach a nerd to be sensitive to girls is like trying to teach a dog Jamacian, and expect it to talk back" - Hansen302 [more]
Go Back   Chief Delphi > Technical > CAD
Unread 06-06-2012, 23:34
Robogineer1649's Avatar
Robogineer1649 Robogineer1649 is offline
AKA: Adam Molnar
FRC #1649 (E.M.S.)
Team Role: Driver
Robogineer1649 will become famous soon enough
Cad Softwares
I was looking into doing Cad next year for our team and I am in charge of picking the Cad software for next year and I have no idea where to start. One of our mentors has some experience in solidworks and others in creo 5. I also know that I have the software for both autocad and inventor professional so any help would be great.
Thanks in advance.
Unread 06-06-2012, 23:47
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Cad Softwares
http://www.solidworks.com/sw/educati...mpetitions.htm
SolidWorks is SO User friendly i would HIGHLY Recommend it. You can click on the link above and fill out the survey to get a free copy of it.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 07-06-2012, 00:20
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
Re: Cad Softwares
Here's a question: have you asked the students on your team anything on this issue?
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 07-06-2012, 00:24
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Cad Softwares
There are tons of threads about this. Searching for them would help you out a ton!
But the bottom line is:
-What do your mentors know?
-What does your school use? (If they have CAD)
-What do your shops use?
Both Solidworks/Pro.E (Creo) are excellent choices and widely used in the field. Solidworks is a bit easier IMO and more user friendly. Your mileage may vary.
-RC
-RC
R.C.
MadTown Robotics Team 1323
Unread 07-06-2012, 01:12
Re: Cad Softwares
In a Creo/Solidworks debate, my experience was that back when I was a student on an FRC team, I tried to learn Pro-E (what Creo was called at the time) twice, and I really don't think that I could use it right now without a tutorial or three. I learned Inventor once, and l used that to learn Solidworks a few years later when I went to college.
Unread 07-06-2012, 04:11
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
Re: Cad Softwares
In my personal experience, Inventor is probably the easiest of the four programs you've listed, with SolidWorks being a little more difficult (this could just be because Inventor was taught in engineering classes at my school). Creo is probably the most powerful of the three, but much more difficult to learn. I will say that Creo is what is used in the production facility I currently work at for designing plastic injection molds, and that it has the benefit of being able to create the CNC programs used without having to export data into another program. I don't know how worthwhile it would be to learn, though since you have mentors who do know it, perhaps learning it might not be too bad. Just keep in mind that it does have a steep learning curve, by my understanding. AutoCAD is a bit of a different beast altogether. In my own, somewhat limited experience with AutoCAD, I found that it was less about manipulating 3D objects and more about dealing with 2D drawings representative of 3D objects. I had quite a bit of trouble learning how to use it just because of the significant difference in paradigms from Inventor, which is what I learned first.
Now, all of that aside, definitely keep in mind that what your mentors can teach is a very important factor here. Learning basic CAD is one thing, but really knowing how to use the software opens up a lot of possibilities. For example, the team I graduated from and now mentor uses a good deal of stress analysis within Inventor during certain stages of design, which has saved a good deal of time and effort that otherwise would have been spent prototyping designs that can't hold up under the stress we expect to begin with, not to mention the help it is in designing components that are lighter but can still withstand loads. If your mentors are learning with you, you're not necessarily going to be using said functionality any time soon, so with this in mind I'd recommend choosing either Creo or Solidworks. Possibly sit down with those mentors you'd be working with and discuss your options as well, and ask them about pros and cons. They can probably explain any of that much better than any of us can over the net
