Re: pic: Robostangs 2012 Final Robot
Rock west composites.
On the subject of a name, last year was Scorpio, so perhaps Sagittarius is appropriate. |
I was just browsing that site today. Can you point me toward the exact materials used for both your 2011 and 2012 robots?
Unfortunately I can't remember more than outer diameters off the top of my head (3in, .75in and .5in iirc). I'll see if I can find some more info once we can get back into our lab.
Wow that carbon tubing is surprisingly affordable
The large uprights are 83mm in diameter, 4-bar arm is 1.25in diameter, and the barrel and ingester is .75in diameter. Most are in 60in lengths.
#7
How did you find the 17 FPS. Was the robot still "easily" controllable, or would a slower speed have helped.
#8
Driver isn't on chief delphi, but he has the most natural talent I've seen out of a driver. He used the speed well and we have it drop into low gear if the arm is raised. Just because it can go fast doesn't mean he has the joystick maxed out often. Also, with a fast drivetrain I highly recommend having a low gear as well, we used it a lot.
