Go to Post The only dumb question is the one you don't ask. - E. Wood [more]
Unread 11-01-2003, 17:39
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Globe Motor + Lead Screw = Confusion
I have a simple question, really. I hope it has a simple answer.
What's the simplest, most efficient, adequate way of fixing the provided lead screw to the shaft of a globe motor.
The globe motor has a flattened shaft. Can I just put a hole and flats in the lead screw and stick it on the motor shaft?
Darn threads.
--Madison--
...down at the Ozdust!
Unread 11-01-2003, 17:49
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
The lead screw isn't that much bigger than the globe shaft, so you're probably going to need some kind of coupling so it doesn't break through. I'd recommend removing the threads from the last inch or so and getting a decent coupling kit from small parts or MSC. They're fairly cheep and fairly reliable. Whatever you do, avoid set screws at all cost!
Also, be very careful to fully support the lead screw in at least two places as the globe can't take ANY side loads.
Unread 11-01-2003, 18:24
Madison's Avatar
FRC #0488 (Xbot)
That's sort of what I figured. I was just hoping someone would say, "It's okay, that'll work!" or something. They still can
Space is at a premium, so I want to keep everything as small and simple as possible. I'll shop around for shaft couplings.
--Madison--
Unread 11-01-2003, 19:12
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
It's ok that'll work...
Now get it done!!!!
jk, actually i think that it might be easier just to go thorough the shaft.... the word kit has never appealed to me much
but neither has the word DIRECTIONS, so......
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 12-01-2003, 01:15
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
It definitely depends on the forces associated with your application. But for not-too-high loads you should be just fine with a coupler that puts a set-screw on the globe motor output shaft and a pin through the lead screw. We've had decent success in the past with pinning the lead screws in an aluminum coupler.
-Joel
Unread 12-01-2003, 11:21
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Heh. We discovered that in 2000 after burning up about 7 Globe motors on our lock for the bar-hanger. Globe + side load= magic smoke.
Jeff Waegelin
Unread 17-01-2003, 16:45
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
We have had good experances with set screws on flattend shafts, we actually had this setup on a vandoor at full stall and it never came loose.
But I would get some 1/2" steel and make an coupler before I would buy one. Its really not that hard to do if you think about how its made.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Globe Motor archiver 2000 0 24-06-2002 00:15
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
Lead screws or globe motors, anyone? archiver 1999 3 23-06-2002 21:52
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
