Go to Post As guests in the city, we should make an effort to do some fundraising for the folks affected by the storm. Any ideas out there? - Jon236 [more]
Unread 11-06-2012, 23:21
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: Affordable 3D Printers
You will not meet your requirements with your budget listed, no matter how much work you do yourself. I own a maker bot, and they are nice, however, if your company is serious about this, it will cost you on the order of $25000 for a good base machine and support equipment. A maker bot or other diy machine will require more babysitting and tending than they will be willing to provide, whereas a professional machine designed for such use will be an asset. To my knowledge you can not buy any RP machine that will give you .001" accuracy, not even the 200k machine I worked with could do that. Sorry to burst your bubble, but I think you should call a few company and see what there is on the commercial side of things. $300 will not even buy the electronics to run one of these machines.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
