Go to Post Reading Andy Bakers post- priceless :D - thoughtful [more]
Unread 11-01-2003, 18:24
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally posted by rbayer
The lead screw isn't that much bigger than the globe shaft, so you're probably going to need some kind of coupling so it doesn't break through. I'd recommend removing the threads from the last inch or so and getting a decent coupling kit from small parts or MSC. They're fairly cheep and fairly reliable. Whatever you do, avoid set screws at all cost!
Also, be very careful to fully support the lead screw in at least two places as the globe can't take ANY side loads.
That's sort of what I figured. I was just hoping someone would say, "It's okay, that'll work!" or something. They still can
Space is at a premium, so I want to keep everything as small and simple as possible. I'll shop around for shaft couplings.
--Madison--
...down at the Ozdust!
Globe Motor archiver 2000 0 24-06-2002 00:15
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
Lead screws or globe motors, anyone? archiver 1999 3 23-06-2002 21:52
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
