Go to Post Aaaaah! I think my head just exploded from looking at this awesomeness. You guys are great. This is super cool. :) - Ian Curtis [more]
Unread 11-01-2003, 19:46
JTH JTH is offline
#1447 (Panther Robotics)
JTH is an unknown quantity at this point
Send a message via AIM to JTH
The control system is disabled at the end of the match, which will in turn make the robot not drive outputs. So basically, relays will return to a non-asserted state and vfd's will pass no power.
For pneumatics, it means that single solenoid valves will return to original postion and double solenoid valves will stay in the last state.
For motors, it means they will lose power. If there is an anti-backoff mechanism in the gearbox, it will stay where it is. If there is not an anti-backoff mechanism, an arm could stay where it is is balanced or if friction is enough to counteract the force of gravity.
Unread 20-01-2003, 12:27
Team852 (DB) Team852 (DB) is offline
#0852 (The Athenian Robotics Collective)
Team852 (DB) is an unknown quantity at this point
Note
I believe that pneumatics remain pressurized, even if your compressor is turned off, so an arm would remain extended. This was evident last year, when Team 852's robot always had to have its pressure system evacuated before it was unlatched from a goal. I believe that we were using double-solenoid valves.
Unread 20-01-2003, 15:33
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Originally posted by Caroline
Oh, and by the way, it's "Hey guys, I've got best idea!"
Not to be picky, but shouldn't it be "Hey guys, I have the best idea!"
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 20-01-2003, 19:52
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
the entire concept is moot due to more recent updates, no negative points, no controlling opponent scores, none of it...
Trust, Love, and Magic
Long list of Thanks/Congrats from 461. Josh Hambright Thanks and/or Congrats 10 08-04-2003 12:49
hey guys, I need some help yelly Scouting 14 23-03-2003 21:04
Now it's my turn to say THANK YOU. archiver 2000 0 23-06-2002 22:56
great storyboard idea SharkBite 3D Animation and Competition 0 15-01-2002 20:39
Hey! Please Read this!! A MICHIGAN Kickoff is in the works! skrussel Rumor Mill 1 29-06-2001 21:31
