Go to Post Given how easily these things pop, is "Blow Out Pricing" really the best choice of words? - ahecht [more]
Unread 16-06-2012, 22:20
spacepenguine spacepenguine is offline
AKA: Ian Hartwig
spacepenguine is an unknown quantity at this point
Re: Controlling methods
Find a blue control box from the first year the cRios were around. That was 2009/lunacy I believe. My still has ours. We'll use it in a project like that eventually.
Edit: Although, that does still require the cRio, which is more expensive than most small netbooks. If you just want to use the KoP up to the Victors/Jaguars, you can use anything that can output a PWM signal. An arduino or other small microcontroller + io board for example.
2008-2011: #226 - The Hammerheads
