Go to Post I'm pretty sure Andrew Baker and Andy Baker are the same person. Then again, Andy may just be holding out on us. - Amanda Morrison [more]
Unread 16-06-2012, 21:36
1502's Avatar
1502 1502 is offline
We're having Technical Difficulties
AKA: Ryan G
FRC #1502 (Technical Difficulties)
1502 is just really nice1502 is just really nice1502 is just really nice1502 is just really nice
Controlling methods
Our last cart used all wheelchair electronics. The one in progress right now won't use them at all so we want to use as many of our extra FRC KOP electronics as possible. So my question is what is the best way to run this cart that preferably doesn't include a laptop?
We make easy things look difficult, everyday!
Unread 16-06-2012, 22:20
spacepenguine spacepenguine is offline
AKA: Ian Hartwig
spacepenguine is an unknown quantity at this point
Re: Controlling methods
Find a blue control box from the first year the cRios were around. That was 2009/lunacy I believe. My still has ours. We'll use it in a project like that eventually.
Edit: Although, that does still require the cRio, which is more expensive than most small netbooks. If you just want to use the KoP up to the Victors/Jaguars, you can use anything that can output a PWM signal. An arduino or other small microcontroller + io board for example.
2008-2011: #226 - The Hammerheads
Unread 16-06-2012, 22:44
1502's Avatar
AKA: Ryan G
It has to be mobile so how would that be powered?
Unread 16-06-2012, 23:23
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
An arduino with some switches would be probably be your best bet, the ardunio takes in 5v and can output PWM the victor needs.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 17-06-2012, 08:42
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Don't forget about the old IFI control system either.
Unread 17-06-2012, 11:29
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
servo tester + any pwm based esc. if you want to have a "tank drive" style drivetrain in the cart, use two esc's, two servo testers and a v-tail mixer.
Unread 17-06-2012, 17:40
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
VEX works great for small projects thats what were using for our cart
