Go to Post Why did they get rid of the headphone jack though? =p - sportzkrazzy [more]
Unread 17-06-2012, 14:06
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Arduino and cRIO serial connection
I've been working on using an arduino to control lights and maybe read sensors on our robot. I have decided to try to use serial instead of SPI or I2C because there isn't much documentation about the Arduino being the slave for either of them. I believe that the cRIO's serial port uses full voltage RS-232 serial and the arduino uses 5v TTL. I have found an old MAX232 based level converter board that I have laying around and I think that the cRIO will work with it. I know how to connect the Tx and Rx of the cRIO and Arduino, but I don't know if or what I have to do with the other pins. Do I only need ground, tx, and rx, or do I need to connect the others?
Unread 17-06-2012, 17:12
Meshbeard's Avatar
Meshbeard Meshbeard is offline
Previously of 422
AKA: Jonas
FRC #0190 (190)
Meshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to allMeshbeard is a name known to all
Re: Arduino and cRIO serial connection
I wouldn't abandon the I2C interface yet.
http://wiring.org.co/learning/libraries/ has some examples of how to use the arduino as a slave in an I2C system. Look under "slave sender."
Unread 18-06-2012, 16:03
apples000's Avatar
Wow, I had no idea that the arduino could be a slave. I was using an older version of the wire library that did not have good documentation. I would like to use i2c, but I have no idea how to send more than one byte between the two devices. Do you know where I could find an example for sending an integer or a string? I can only seem to find information about sending one byte.
Unread 18-06-2012, 18:59
Gdeaver Gdeaver is offline
FRC #1640
On this page look at the master slave examples for the wire lib.
http://arduino.cc/en/Tutorial/HomePage
Unread 18-06-2012, 21:04
apples000's Avatar
Thanks for the quick reply! I understand how it works, but I am unsure how I would go about storing the transmitting information to a variable. From what I understand, it sends one character at a time. Then, for the last one, it will send the end of the line. I think that if I wanted to store the string, I would have to add all of the letters together, then stop when I got the new line. For what I am trying to do, I would like to send several integers. If I sent three integers separated by commas (12,45,65), could I read it using
void receiveEvent(int howMany)
  while(Wire.available())
 int a = Wire.parseint();
 int b = Wire.parseint();
 int c = Wire.parseint();
