Go to Post This is the hint that never ends, yes it goes on and on my friend. Some people start guessing not knowing what it was, and they'll continue to guess forever just because... - JaneYoung [more]
Unread 18-06-2012, 21:56
EE question: convert RS232 voltages to RC servo
Looking for EE's to comment please.
I want to convert a -12V to +12V PWM signal to RC servo voltage levels (0 to +5V), with sufficient current to reliably drive a Victor.
I cannot locate any specs for the Victor's input impedance and required minimum input voltage.
I'm thinking a simple circuit like this will do the job. The questions I have are these:
- Is 1200 ohm a small enough output impedance to reliably drive the Victor's input?
- Is the 2.7MegOhm small enough to allow the 12V input to drive the 2N3904's base?
- Will the transistor operate as desired (i.e. shut off) with a -12V signal at the base, without damaging the transistor?
- Will these resistance and voltage values keep the 2N3904 within a safe operating range ?
