Go to Post When you start thinking of FIRST as a robotic building contest you have left the pavement and you are in deep weeds. - KenWittlief [more]
View Poll Results: Will There Ever Be Negative Scores?
Yes, all the time. 9 13.43%
Yes, but not that often (once a day). 18 26.87%
Yes, but only when the best of the best go against eachother (ie Championship). 3 4.48%
Yes, but only durring elimination rounds. 7 10.45%
No, never. 30 44.78%
Voters: 67. You may not vote on this poll
Unread 11-01-2003, 17:19
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
So, do you?
Unread 11-01-2003, 17:38
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
considering it seems FIRST hasn't quite recognized their error, I think update 4 will have a clause so there won't be negatives. This thread is kind of pointless until FIRST gives a yay/nay on whether or not they intend to allow negatives
Unread 11-01-2003, 18:06
Joe3's Avatar
Joe3 Joe3 is offline
Joe3 has a spectacular aura aboutJoe3 has a spectacular aura aboutJoe3 has a spectacular aura about
Send a message via AIM to Joe3
Originally posted by dlavery
You guys are 90% there. Now finish the thought.
Joe's original point was spot-on. One alliance can directly affect the score of the opposing alliance by playing with the opponent stack height (to be complete, you should also assume that the opposing alliance is doing the same to your stacks). A robot could lift a container up to be equivalent to a 10-high stack (hmm, 4.8lb container at 14.75*10=12feet above the base of a 130 lb robot, plus a little "robust physical contact", yields a CG rapidly moving outside the conservative support polygon...), and it is possible to create a negative score.
At this point it is worth pointing out that this potential is exactly why no teams should start any game with a strategy that has them plunking down on top of the ramp and just sitting tight with the expectation that they have a lock on a win with 50 points in the bank...
A little more analysis is then done, with a broader view. Yes, negative scores are possible. But then there are those pesky QP and EP calculations. If your opponent gets a negative score, which means you will probably win, then your alliance gets twice as many negative QPs! You better be REALLY FRIENDLY with your alliance partner if you cause this! Sure, you won the game, but - through your own actions - you actually DROP in the QP standings. By giving your opponent a negative score, you may actually cause them to move ahead of you in the overall tournament standings as you drop down the QP ladder. And because the scoring systems are the same in the qualifiers and finals, this is also true in the finals!
So it quickly becomes obvious that while negative scores are possible, they are generally a bad idea. So their potential use becomes self-limiting. There are a very few particular circumstances where you might be willing to take the QP/EP hit, just to ensure that your opponent moves to a certain position in the QP/EP standings (think about this and you can identify those few circumstances). "Sacrifices" could become an element of the competition! It works in baseball and chess, so why not?
What does this mean? It means that there is a potential whole new level of strategy in the tournament (notice I said "tournament" and not "game"). It means that teams need to start thinking beyond the effects of the current match, and start thinking about multi-match strategies.
Don't automatically assume that this is a "loophole!" This is not an accident that wasn't thought through. It is actually an opening onto a new level of the competition that requires a little more thought and offers more complexity to the players.
-dave
Considering that he created the game and said that tis is not a loophole, and was planned on by FIRST, don't expect this to change
Unread 11-01-2003, 18:30
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
Personally I think FIRST might have slipped when it said what it did in Update #3. I find it hard to beleive that they would put in negative scoring.
BUT, if it does really happen, I don't think that it will happen too often...There are LOTS of boxes out there, so it is unlikely that there will be more boxes in the tallest stack than boxes on the floor.
We shall see.
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 11-01-2003, 19:30
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
well if a very underhanded team creates a "virtual stack" of 30 (which would be possible mind you) then there is a VERY slim chance you could get above a negative score.
that's the whole discrepancy...virtual stacks are just...wrong. it's ok to get MORE QP's...but to give a team a negative score is totally not in the spirit of FIRST, and shouldn't be within any team's ethics.
i should hope if they don't change it that the teams will atleast say "hey...that's wrong guys (and gals)."
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 11-01-2003, 19:39
Doug's Avatar
Doug Doug is offline
#0122 (Nasa Knights)
Doug is an unknown quantity at this point
now im no physicist or anything but lets take your 30 stack arm thats 60 feet long right? if anyone can raise a 5 pound box 60 feet in the air and they are able from being tipped by their opponents which would not only disable them but most likely mangle their precious lifting arm that is if it doesnt hit someone in the audience on the head. I think we are talking virtual stacks of 10-15 maybe from the truly dedicated robots. it will all be ok im sure.
yeah sorry i dont beleive in punctuation
122's stacking machine
Unread 11-01-2003, 19:44
Jeremy_Mc's Avatar
GitHubber
that was purely theoretical...but then again many people said you couldn't get 3 goals and hold them last year....two teams i know of proved them wrong...
*jeremy
Unread 11-01-2003, 19:50
jonathan lall's Avatar
jonathan lall jonathan lall is offline
FRC #2505 (The Electric Sheep; FRC #0188 alumnus)
jonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond reputejonathan lall has a reputation beyond repute
Send a message via MSN to jonathan lall
So do I? Nope.
Unread 11-01-2003, 19:54
Joe Matt's Avatar
*jeremy
Grrrrr
You mean 3 teams, right?
Unread 11-01-2003, 20:30
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
It's possible but I highly doubt we'll see many (if any) negative scores. First, a robot will have to raise a box in the air high enough to get a possible negative score. Second, it'll be hard to have just 3-5 boxes on one side and like 40 on the other. Third, the opposing team is not stupid enough to give them negative points because it'll lower their final score (or even make it negative).
Unread 11-01-2003, 20:32
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
You can't because it would screw up the averages for the qp. One negative score and your dead. First wouldn't allow that. Btw how would you get a negative score.
Unread 11-01-2003, 22:26
D.J. Fluck
Posts: n/a
I get it...
There is no way you can get negitive scores. The rule is unclear but after reading it and crumbling up papers for severals minutes, I get it
The height of the tallest stack located in the scoring zone (the “multiplier stack”),
measured in whole Stack Height Units (as defined in SC9) is subtracted from the total
number of containers to establish the “base score.” Containers in additional stacks of the
same height will be scored normally
I can see where you get the idea thinking that you subtract the stack score and get a negitive number, but this is not really the case so if you have 4 tubs stacked up and no additional tubs, you (in theory) would get a score of -4 (0 tubs - 4 (for the stack). BUT thats not the case. FIRST IS counting all the totes, so if you have the 4 in a stack and no other totes on the floor, you count the 4 total tubs in your first subtraction number. In the end you subtract 4 (total tubs) - 4 (stack size) and you get a score of 0.
Read the rules again. Thats how I understood and Im not the only one believing this.
Not a wrong rule, just horribly worded
Unread 11-01-2003, 22:32
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
DJ, I believe that you are correct. You just need to read over the rules SEVERAL times. Exactly what FIRST said at the kickoff numerous times and in the rule books.
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 11-01-2003, 22:33
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Conspiracy
DJ,
Pay no attention to the man behind the curtain.
These guys are trying to cause a commotion over this... it's all a big distraction. We know the intent... now, get back to your electrical area and finish the wiring for that hovercraft.
Andy B.
ps... "these are not the negative points you are looking for"
Unread 11-01-2003, 22:42
41246017 O-('_'Q)
AKA: Y C
If a robot lifts a box up, say 4 box units and there are no other boxes on the side, wouldn't the score be...4 box units times (1 container - 4 container for stack) which means...-12 points? Also, since the minus points is measured by box height, if all 3 of your boxes are on its side and you have no other boxes, couldn't you technically have a box height of 4 and a total of 3 - 4 boxes, which leaves you with -4 points?
One up last week's scores soap108 Regional Competitions 2 25-08-2003 12:54
Stop Posting About Negative Scores Adam Y. General Forum 25 13-01-2003 15:44
National championship scores? Thoughts on the game. archiver 2001 1 24-06-2002 03:23
Scores? We've got your scores right here... archiver 2000 2 23-06-2002 22:27
Why is'nt FIRST publishing scores? Ben Mitchell General Forum 7 15-03-2002 14:38
