| Thread Tools |
Rating:
Display Modes |
#61
Re: M.A.R.C. 2012 Invite list
Yes, a jump drive is an octocanum.
#62
OK now if you're bored, feel free to provide bridge balance assist information, if you wish to share. I'm only looking for systems that can be used while your bot is ON the bridge, not while off the bridge helping others to balance.
I plan on visiting pits for this, but early info is good info. Thanks! Please use the following classifications: STINGER OUT - Stinger of any kind applied outside of frame perimeter STINGER IN - Stinger of any kind applied inside frame perimeter BRAKES - Braking/stay put system - mechanical brakes, pneumatic pad onto bridge surface, etc. PID BRAKES - Deserves its own category if no other mechanical braking present, as control stops once match ends. OVERHANG(+) - Can hang at least 12" of robot off the bridge. Use OVERHANG+ if you have additional features to secure the bot that don't fall into any other category - wood blocks, wedges, tilting arm to affect COG :-), etc. 33....WIDE..STINGER OUT 48....LONG..STINGER IN..OVERHANG+ 51....WIDE..STINGER IN 67....WIDE..STINGER OUT 68....WIDE.. 70....WIDE..STINGER OUT 107...WIDE.. 123...LONG.. 191...LONG.. 217...LONG..STINGER IN..OVERHANG+ 240...LONG.. 245...WIDE.. 279...LONG.. 280...LONG.. 302...WIDE.. 308...LJMP.. 461...LONG..OVERHANG 469...SQUA..STINGER OUT 470...WIDE.. 494...WIDE..STINGER OUT 503...LMEC.. 548...LONG..STINGER IN..OVERHANG 815...WMEC.. 830...WIDE.. 862...LONG..STINGER IN..OVERHANG..BRAKES 910...WIDE.. 1023..WIDE..STINGER OUT 1243..WIDE.. 1504..LONG.. 1528..WIDE.. 1675..LONG..STINGER OUT..OVERHANG 1718..WIDE..STINGER OUT..BRAKES 1732..WIDE.. 1918..WIDE.. 2137..WIDE.. 2337..LONG..STINGER IN..OVERHANG..BRAKES 2604..WIDE.. 2612..LONG.. 2832..LONG.. 2834..WIDE..STINGER OUT 2851..WIDE.. 3096..WIDE.. 3098..WIDE.. 3175..WIDE.. 3302..LONG.. 3322..WIDE..STINGER OUT 3357..WIDE.. 3539..LONG.. 3547..LONG.. 3641..LONG.. 4395..WIDE.. Last edited by Travis Hoffman : 06-19-2012 at 11:57 AM. |
#63
217 - stinger in, overhang, overhang angle management (aka wood blocks directly behind the center wheels).
#64
2337 also added pneumatically powered brakes (inspired by 1718) for the IGVC offseason event two weeks ago (used successfully for single, double/co-op, and a triple balance).
#65
Added info for 217 and 2337. Presumably 2337 overhangs 12" if tripling, so I added that as well.
#66
You can add stinger out for 1718 (along with brakes).
#67
1675 - stinger out, overhang.
This is a different and much simpler stinger than what we had at the regional level, but its also somewhat untested as its been built away from our shop (uses the same gearbox as previous stinger and has a shorter moment arm, so theoretically it SHOULD work BETTER than before....) |
#68
Stinger/arm out.
If one partner has stinger, we like to be the first one up for triple balance and rotate our arm all the way down to under the bridge once the arm has gone over the edge. That way, there is no possibility of the bridge not balancing. |
#69
For clarification, our "Stinger In" is simply a 'dingus' - 148-style - a large pneumatic cylinder. Last edited by kenavt : 06-18-2012 at 10:16 PM. |
#70
461 overhang (~16 inches)
-Duke |
#71
51 has a Stinger(in).
1023 - Stinger Out
#73
My list above updated with info through previous post. Thanks for sharing - keep em coming!
#74
548 - Stinger In, Overhang
#75
Both Team 40 and 494 are both STINGER OUT, there front flippers are there stingers.
