Go to Post But altering register values via bitwise operations in nested ternary commands is so much fun! - artdutra04 [more]
Unread 19-06-2012, 12:26
4085's Avatar
4085 4085 is offline
Technical Difficulties
AKA: Sebastian Brosious
FRC #4085 (Technical Difficulties)
4085 is an unknown quantity at this point
Vision Tracking Tutorial
Hello fellow programmers! Once again the Rookie team 4085 is pleading for help, for vision tracking explanations are either vague and or too confusing so i beg of help to program in to autonoumus a vision tracking camera that will move the tank drive wheels on our robot and shoot once aimed. We use labveiw and sorry for asking so much questions gotta start somewhere >.<
_______________________________________________
WE ARE...
Raiders!
Unread 19-06-2012, 12:35
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Re: Vision Tracking Tutorial
Have you read this: https://decibel.ni.com/content/docs/DOC-20173
It goes through the logical steps of finding and tracking the targets using NI's Vision assistant software (that writes Labview code).
I don't often use Labview, but I am pretty sure there is a sample program that tracks targets.
Unread 19-06-2012, 14:12
Tommy F.'s Avatar
Tommy F. Tommy F. is offline
Yeah! Collages!
AKA: 7h0m45
FRC #1985 (Robohawks)
Tommy F. is just really niceTommy F. is just really niceTommy F. is just really niceTommy F. is just really nice
The directory C:\Program Files\National Instruments\LabVIEW 2011\examples\FRC\Vision\Rectangular Target Processing should bring you to the Rectangular Target Processing vi's and project. During the season we took this and adjusted it so we could find targets.
The processing takes the image and converts it to an X/Y coordinate grid, where x=0 and y=0 are the center of the image. When the program reads targets, it shows the x and y coordinates of the center of that target.
To find the target (the highest one), we compared the target's y coordinates, and chose the target with the highest y value. Then for changing the orientation of the bot, we got the x coordinate from the target with the highest y coordinate and made that the process variable for our PID loop, and put 0 as the setpoint for our PID loop. We then used a gyro on our robot and compared it with the process variable, to see which direction the bot needed to go (a negative x value would mean turn right, a positive left) until the output of the PID was at 0.
Or at least I think that's how we did it. It's been a while. I'll be sure to look over this again in the near future so I might be able to help you out more.
Oh, and all of this didn't require the use of the NI Vision Assistant, since most of the code you need is already in the Rectangular Target Processing example.
FTC 289, 290 & 291 :: FRC 1985
2013 St. Louis Regional Semi-Finalist (with 3411 and 4330), Industrial Design Award
2013 Queen City Regional Winner (with 379 and 447)
Unread 22-06-2012, 16:00
4085's Avatar
Thanks , im having a question relating to the vision tracking, how do I get the information coming from the processed images into a tank drive value in autonomous. please and thank you we have an off season competition tommorow
WE ARE...
Raiders!
Unread 22-06-2012, 16:09
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Ahah! So that's what they want you to figure out. Look at what data is available to you. Isn't there a nice array of targets found? How about simpiy index the first array element. Now what does each element of the array hold? Well there is an X and Y coordinate. When you're centered on the target, x should read 0.
Maybe that's enough to get you going.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 22-06-2012, 16:22
JamesD's Avatar
JamesD JamesD is offline
[:o)
AKA: James David
FRC #0330 (BeachBots)
JamesD is an unknown quantity at this point
Here's some links that should help:
Labview - incorporating rectangular target processing.vi
http://www.chiefdelphi.com/forums/sh...d.php?t=104516
Vision Tracking Help:
http://www.chiefdelphi.com/forums/sh...d.php?t=104330
Unread 22-06-2012, 19:56
Depending on how you processed your image, you might just get the x,y of the pixel coordinates. So if this is the case, and you want a number -1<=x<=1, use this formula:
drivingValue = (pixelValue - (maxImageDimension / 2)) / (maxImageDimension/2)
where maxImageDimension is the size of that image axis.
That way, you can get an value between that could easily be plugged into an algorithm or speed controller. (ex. 640,480 turns to 1,-1)
Hopes this helps. Good luck tomorrow! (I Wish my team was doing something offseason)
