#166
Re: 2012 IRI Predictions
461 Overhang (~16 inches)
-Duke |
#167
Correction:
2168 .Long.. Stinger In |
#168
Inside. Just barely.
#169
3310 stinger 'out' though it does touch our bumper in the front ;o
#170
829 short 12" overhang and I just found a 24" cylinder while moving our shop
#171
2826 is STINGER IN, unless they've modified their bot since I last saw them.
3193 is OVERHANG+. 1023 is STINGER OUT, from the MARC thread. 548 is STINGER IN..OVERHANG, from the MARC thread. Last edited by Travis Hoffman : 19-06-2012 at 11:52. |
#172
#173
341 is wide, has an inside-the-frame-perimeter stinger, can hang up to 10" off the edge (requiring a total of 18" of real estate on the bridge when we go up in the rear - not including bumpers, which are low on our leading edge to get under any high bumpers in front of us), and has software brakes.
#174
I predict at least 1 team unbalancing a bridge while attempting to show off their brand new stinger... So far I have seen at least 1 team unbalance a bridge in order to show their stinger at each event I have attended.
#175
340 is STINGER OUT with OVERHANG+
#176
Stolen from http://www.chiefdelphi.com/forums/sh...0&postcount=62 and applying to IRI (Thanks Travis Hoffman)
STINGER OUT - Stinger of any kind applied outside of frame perimeter STINGER IN - Stinger of any kind applied inside frame perimeter BRAKES - Braking/stay put system - mechanical brakes, pneumatic pad onto bridge surface, etc. PID BRAKES - Deserves its own category if no other mechanical braking present, as control stops once match ends. OVERHANG(+) - Can hang at least 12" of robot off the bridge. Use OVERHANG+ if you have additional features to secure the bot that don't fall into any other category - wood blocks, wedges, tilting arm to affect COG :-), etc. 16 ...Swerve.. 25 ...Long..Stinger In..Brakes 27 ...Long.. 33 ...Wide..Stinger Out 45 ...Wide.. 48 ...Long..Stinger In..Overhang+ 51 ...Wide..Stinger In 67 ...Wide..Stinger Out 68 ...Wide.. 71 ...Swerve.. 111 ..Long..Stinger In 118 ..Wide..Stinger In 125 ..Long.. 148 ..Wide..Stinger In 192 ..Long.. 217 ..Long..Stinger In..Overhang+ 233 ..Long.. 234 ..Wide.. 245 ..Wide.. 269 ..wide.. 292 ..wide.. 330 ..Long..Stinger In 340 ..Long..Stinger Out..Overhang+ 341 ..Wide..Stinger In..10" Hang..PID Brakes 359 ..Long.. 379 ..Long.. 399 ..Wide.. 447 ..Long.. 461 ..Long..Overhang 469 ..Square..Stinger Out 503 ..Mecanum.. 548 ..Long..Stinger In..Overhang+ 573 ..Long.. 624 ..long.. 744 ..Long.. 772 ..Long..Overhang 781 ..Long.. 829 ..Wide..Overhang 868 ..Square.. 907 ..Wide..Stinger Out..PID Brakes 973 ..Swerve..Stinger Out..Brakes 1023 .Wide..Stinger Out 1024 .Wide.. 1114 .Long..Stinger In, PID Brakes, Overhang+ 1538 .Long.. 1592 .Wide.. 1640 .Swerve.. 1676 .Long..Stinger In 1714 .Wide.. 1718 .Wide..Stinger Out..Brakes 1730 .Wide.. 1732 .Wide.. 1741 .Mecanum.. 1902 .Long.. 2054 .Long..Stinger Out 2056 .Long..Stinger Out 2168 .Long..Stinger In 2194 .Wide.. 2337 .Long..Stinger In..Overhang..Brakes 2590 .Wide.. 2614 .Long.. 2826 .Long..Stinger In 2834 .Wide..Stinger Out 2949 .Wide.. 3098 .Wide..Stinger Out 3138 .Long.. 3193 .Long..Overhang+ 3310 .Long..Stinger Out 3322 .Wide..Stinger Out 3357 .Wide.. 3940 .Wide.. 3947 .Long.. 4334 .Wide.. Last edited by Gregor : 20-06-2012 at 16:50. Reason: Updated 340 |
#177
We are still missing 37 teams!
Come on lets keep going ![]() |
#178
Did you change your stinger since this video: http://youtu.be/Ar6CMCwlW5k ?
#179
781 has a fairly reasonable overhang.... currently we can take up as little as just over 20"..... if we have driven straight onto the bridge. (thanks to our polycord and sliders)
Our low gear pretty much works as a break when the robot is on (you can tip the bridge down and it hardly moves until you shut it off). Last edited by JJackson : 24-06-2012 at 00:07. |
#180
