Go to Post Thanks to everyone who made the regional possible - I know my team had a blast and I'm pretty sure most other teams did too. - Steve Howland [more]
Unread 21-06-2012, 01:42
Andrew Lawrence
Posts: n/a
AM Shifter: 2:56:1 spread vs. 4:1 spread
I've been looking into the AM shifter transmissions, but have no idea how to calculate the 2:56:1 or 4:1 into my calculations (using JVN design calc). Can someone explain the two to me, and if possible the gearing that goes on in there? This is probably really simple, but I've spent 3 days trying to figure this out.
Thanks!
Unread 21-06-2012, 01:50
rutzman rutzman is online now
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Re: AM Shifter: 2:56:1 spread vs. 4:1 spread
Thanks!
The 2.56:1 has final reductions of 10.67:1 and 4.17:1.
The 4:1 has final reductions of 10.67:1 and 2.67:1.
If I remember correctly, the difference comes from flipping a 28:35 to a 35:28, or vice versa.
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Andrew,
The spread is determined by changing the gears inside the transmission. On JVN's calc on the 2 speed section, replace the numbers with the different gear sets available from AM.
If your still a little lost, feel free to hit me up via PM/IM.
-RC
R.C.
MadTown Robotics Team 1323
Unread 21-06-2012, 01:51
iyermihir iyermihir is offline
FRC #0649 (Saratoga MSET)
Team Role: CAD
iyermihir has a spectacular aura aboutiyermihir has a spectacular aura about
Those are the ratios between the high and low gears. The ratios that you would want to put in the calculator are under gearing on the product page.
For the 4:1 spread:
Low Gear: 10.67:1
High Gear: 2.67:1
For the 2.56:1 spread:
Low Gear: 10.67:1
High Gear: 4.17:1
Unread 21-06-2012, 02:04
Andrew Lawrence
Posts: n/a
I sorta understand the spread, but the gears are my main problem. I'm looking at this picture (http://www.andymark.com/PhotoDetails...tCode=am-0001), and don't see what gears are used. I see the two gears in the picture, but I don't think those are the only ones.
Unread 21-06-2012, 05:02
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
AM Shifter AM-0957
Drive PN    Driven PN   Drive NT    Driven NT   SET RATIO   O'ALL RATIO
AM-0018    AM-0024       12              40            3.33
AM-0451    AM-0022       15              48            3.20        10.67
AM-0139    AM-0140       35              28            0.80         2.67
AM Shifter AM-0001
AM-0025    AM-0023       28              35           1.25	     4.17
Also, here is a render of AM-0001 with the gear teeth shown.
Unread 21-06-2012, 08:13
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
2.56:1 Spread
(40/12)*(48/15)=10.667
(40/12)*(35/28)=4.167
2.56:1 Spread
12T input gear (x2 - CIM)
15T small cluster gear (output side)
28T medium cluster gear (motor side)
35T small output gear (motor side)
40T large cluster gear (center of cluster - direct input from 12T)
48T large output gear (output side)
4:1 Spread
(40/12)*(28/35)=2.667
4:1 Spread
28T small output gear (motor side)
35T medium cluster gear (motor side)
Unread 21-06-2012, 09:21
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
the only thing that matters is the final reduction of each of the two speeds.
My Instructables
Unread 21-06-2012, 10:03
Those two gears are the output gears. They're free-spinning. The shifter dog couples one or the other to the hex-shaped output shaft. There are two other relevant gears on the "power shaft" that engage the output gears; they are hidden directly below what you can see.
There are two or three other gears that transfer the output of the motor(s) to what I've called the power shaft. They provide a first-stage reduction from the motor speed, but they aren't involved in the shifting.
Unread 21-06-2012, 11:00
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
I would also caution you to look at your output power vs. speed with the two ratios. The 4:1 has a pretty big power trough between the peak powers. If your system spends a lot of time in this zone it can eat a battery alive.
Mark
Brick walls are for other people. - Randy Pausch
Unread 21-06-2012, 11:01
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
Thumbs up Re: AM Shifter: 2:56:1 spread vs. 4:1 spread
Originally Posted by Tom Ore View Post
AM Shifter AM-0957
AM Shifter AM-0001
I must say, that is a beautiful rendering.
FRC Team 3489 "Category 5"
Unread 21-06-2012, 11:50
Andrew Lawrence
Posts: n/a
Thanks everyone! I understand it now!
