| Thread Tools |
Rating:
Display Modes |
#76
Re: M.A.R.C. 2012 Invite list
Sorry, both Team 70 and 494 are STINGER OUT, their flippers are their stingers.
#77
1918 stinger out. It was first used in troy. we only use it in the case of a triple so we keep it taped in the stowed position, during qualification rounds. Our first triple with 85 and 910 was with no stinger and done in less than 15 seconds from the time we decided we needed three rather than two. Of course that was NOT with the rookie drive team that will be at MARC
#78
Updated.
Please use the following classifications: STINGER OUT - Stinger of any kind applied outside of frame perimeter STINGER IN - Stinger of any kind applied inside frame perimeter BRAKES - Braking/stay put system - mechanical brakes, pneumatic pad onto bridge surface, etc. PID BRAKES - Deserves its own category if no other mechanical braking present, as control stops once match ends. OVERHANG(+) - Can hang at least 12" of robot off the bridge. Use OVERHANG+ if you have additional features to secure the bot that don't fall into any other category - wood blocks, wedges, tilting arm to affect COG :-), etc. 33....WIDE..STINGER OUT 48....LONG..STINGER IN..OVERHANG+ 51....WIDE..STINGER IN 67....WIDE..STINGER OUT 68....WIDE.. 70....WIDE..STINGER OUT 107...WIDE.. 123...LONG.. 191...LONG.. 217...LONG..STINGER IN..OVERHANG+ 240...LONG.. 245...WIDE.. 279...LONG.. 280...LONG.. 302...WIDE.. 308...LJMP.. 461...LONG..OVERHANG 469...SQUA..STINGER OUT 470...WIDE.. 494...WIDE..STINGER OUT 503...LMEC.. 548...LONG..STINGER IN..OVERHANG 815...WMEC.. 830...WIDE.. 862...LONG..STINGER IN..OVERHANG 910...WIDE..STINGER OUT..OVERHANG..BRAKES 1023..WIDE..STINGER OUT 1243..WIDE.. 1504..LONG.. 1528..WIDE.. 1675..LONG..STINGER OUT..OVERHANG 1718..WIDE..STINGER OUT..BRAKES 1732..WIDE.. 1918..WIDE..STINGER OUT 2137..WIDE.. 2337..LONG..STINGER IN..OVERHANG..BRAKES 2604..WIDE.. 2612..LONG.. 2832..LONG.. 2834..WIDE..STINGER OUT 2851..WIDE.. 3096..WIDE.. 3098..WIDE..STINGER OUT 3175..WIDE.. 3302..LONG.. 3322..WIDE..STINGER OUT 3357..WIDE.. 3539..LONG.. 3547..LONG.. 3641..LONG..OVERHANG+..BRAKES 4395..WIDE.. Last edited by Travis Hoffman : 21-06-2012 at 18:26. |
#79
Lightning Robotics is really excited to be competing at MARC this year!
And a correction we do not have brakes |
#80
Just thought I would let everyone know, team 3641 has both Overhang(+) and brakes.
#81
910 is Wide, has a Stinger Out, Brakes, and is only 24" long and requires only 13" of ramp to support the bot (including bumpers).
Looking forward to seeing all of our friends at MARC! |
#82
Does anyone have any advance information on a MARC webcast link or who is providing one?
#83
Webcast, Rankings, Results, Stats, and more. -Duke |
#84
Main Site Link: http://webapps.monroetrojanrobotics.com/marcstats/ Webcast: http://webapps.monroetrojanrobotics....ts/webcast.php Team Rankings: http://webapps.monroetrojanrobotics....stats/rank.php Match Results: http://webapps.monroetrojanrobotics....ts/results.php Last edited by Travis Hoffman : 21-06-2012 at 19:13. |
#85
Kind of late, but 68 has something like brakes. When we are on low gear on the bridge our robot will not/can not move without significant force applied to it.
One of the field reset volunteers thought we were stuck before we switched it to high gear. |
#86
3539 has Stinger In and Overhang.
#87
STINGER OUT - Stinger of any kind applied outside of frame perimeter STINGER IN - Stinger of any kind applied inside frame perimeter BRAKES - Braking/stay put system - mechanical brakes, pneumatic pad onto bridge surface, etc. PID BRAKES - Deserves its own category if no other mechanical braking present, as control stops once match ends. OVERHANG(+) - Can hang at least 12" of robot off the bridge. Use OVERHANG+ if you have additional features to secure the bot that don't fall into any other category - wood blocks, wedges, tilting arm to affect COG :-), etc. 33....WIDE..STINGER OUT 48....LONG..STINGER IN..OVERHANG+ 51....WIDE..STINGER IN 67....WIDE..STINGER OUT 68....WIDE..BRAKES 70....WIDE..STINGER OUT 107...WIDE.. 123...LONG.. 191...LONG.. 217...LONG..STINGER IN..OVERHANG+ 240...LONG.. 245...WIDE.. 279...LONG.. 280...LONG.. 302...WIDE.. 308...LJMP.. 461...LONG..OVERHANG 469...SQUA..STINGER OUT 470...WIDE.. 494...WIDE..STINGER OUT 503...LMEC.. 548...LONG..STINGER IN..OVERHANG 815...WMEC.. 830...WIDE.. 862...LONG..STINGER IN..OVERHANG 910...WIDE..STINGER OUT..OVERHANG..BRAKES 1023..WIDE..STINGER OUT 1243..WIDE.. 1504..LONG.. 1528..WIDE.. 1675..LONG..STINGER OUT..OVERHANG 1718..WIDE..STINGER OUT..BRAKES 1732..WIDE.. 1918..WIDE..STINGER OUT 2137..WIDE.. 2337..LONG..STINGER IN..OVERHANG..BRAKES 2604..WIDE.. 2612..LONG.. 2832..LONG.. 2834..WIDE..STINGER OUT 2851..WIDE.. 3096..LONG..OVERHANG 3098..WIDE..STINGER OUT 3175..WIDE.. 3302..LONG.. 3322..WIDE..STINGER OUT 3357..WIDE.. 3539..LONG..STINGER IN..OVERHANG 3547..LONG.. 3641..LONG..OVERHANG+..BRAKES 4395..WIDE.. Last edited by Travis Hoffman : 22-06-2012 at 01:39. |
#88
Team 3096 is really excited for MARC!
By the way, 3096 is long with an 18” overhang. (not including bumpers) Good Luck! |
#89
Just a quick note - 1504 is mechanum (long). I noticed you had labeled that for other teams as well, like 308 and 503.
#90
Sad, webcast just went off in the middle of the ...
"Volunteer of the Year" Award -- I think it went to Lisa Perez (sp?) of 830 (at one point!) Webcast ... Please come back! Inquiring eyes want to see! ![]() |
