Go to Post Thats what makes FIRST so unique how culture and the time is reflected through our bots, but at the same time we all get along...with no problem. - Dan Richardson [more]
Unread 19-06-2012, 14:10
cesaros cesaros is offline
César Javaroni
FRC #1382 (ETEP Team)
cesaros is an unknown quantity at this point
Lightbulb HELP: Omni Wheels Programming Tricks
Hi Everyone,
My team Will try using omni wheels next week, and I wanna now if have Any kind of advice to give for me.It will be my first time programming a robot with omni wheels too so, please give me some feedback.
Thank YOU! =P
César Luiz Javaroni
ETEP Team 1382
Unread 19-06-2012, 15:16
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: HELP: Omni Wheels Programming Tricks
It really depends on what you mean by "using omni-wheels".
Are you just adding them to a traditional tank drive setup or are you planning on doing some form of holonomic drive? (Andy Mark Omni Wheels)
Or do you mean meccanum wheels which are similar but different than what are normally referred to as omni-wheels.
Unread 21-06-2012, 02:13
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
If you have your omni wheels in a configuration like this,
or are using mecanum wheels I would probably suggest using a game pad because it already has two joysticks on it so there would be less wires and you have up/down/left/right buttons. You definitely need to have dead zones. I would also suggest having a buttons to make it go strait in any direction so that if you push the up button it will have all the motors go forward at a selected speed, down button all go reverse at one speed, left button two go forward and two go reverse at the same speed, and if the right button is pressed do the reverse.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 21-06-2012, 10:56
iyermihir iyermihir is offline
FRC #0649 (Saratoga MSET)
Team Role: CAD
iyermihir has a spectacular aura aboutiyermihir has a spectacular aura about
One thing that my team has done in the past is to put a gyro on the robot. You can then use the gyro to make the robot easy to drive by make it move according to the driver's inputs, but in relation to the driver so that pushing the stick forward will always move the robot away from him or her. This makes it easier for the driver because he or she does not have to worry about robot orientation. I'll see if I can get more information about the implementation sometime today.
Unread 21-06-2012, 12:41
The WPILib RobotDrive functions support the use of a gyro for field-centric control.
Or if you want to do it home-brew, you can find pseudo-code here.
Unread 21-06-2012, 14:36
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
As Team 1717 showed, using a gyro in an omnidirectional drivetrain can be helpful, but the gyroscope itself may be less than wonderful, so be cautious and make sure you get a gyro and setup that will limit "drifting".
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 22-06-2012, 15:56
foote stepped in
AKA: E. Foote
FRC #0868
When using a gyro, make sure you use the correct output. The 2012 FRC gyro has a rate and temperature output, if you use the wrong output you may scratch your head at the results.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
