Go to Post Although it took me a little while to find my niche in the program, every moment spent has been one great memory after another. - Amanda Morrison [more]
Unread 23-06-2012, 11:29
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Joystick
Our standard tank drive regular runs at 50% max speed with a turbo button that boosts it to 100%.
Basically you multiply the joystick output by a constant to send a range of -0.5 to 0.5 to the motor controller. When the turbo button is pressed you double the value. If then statements would work.
My programmer hates it when I look over his shoulder, but I probably could get the code snippets if you want.
