Go to Post It's your duty in FRC to your teammates and alliance partners to put the most competitive robot possible on the field. - Chris is me [more]
Unread 25-06-2012, 18:57
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
Eclipse for Java
I just switched from the Netbeans IDE to the Eclipse IDE. And i installed the plugins for FRC java to work.
I just wanted to know if Eclipse would work with the CRIO. Like has any one actually got their robot working using Eclipse.
Thanks
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 25-06-2012, 23:55
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Eclipse for Java
First off, what was your reasoning behind switching to eclipse? I'm personally interested.
Secondly, netbeans and eclipse will provide the exact same functionality apart from how they perform as an IDE. It's the same java, same virtual machine on the CRIO and same deployment technique. So, it will be the same through both IDEs.
All opinions are my own.
Unread 28-06-2012, 01:20
V. Gray V. Gray is offline
Programmer/Team Captain
AKA: Ben
FRC #3881 (WHEA Robotics)
V. Gray is an unknown quantity at this point
Yes, I was able to get Eclipse working with the Robot. Our team did all of our programming in the Eclipse IDE, and were able to load code on to the robot, as well as edit code through eclipse.
