Go to Post I even have a t-shirt that says "Actually, I -am- a rocket scientist" :) - dlavery [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 28-06-2012, 17:16
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: CAN distance
Originally Posted by nydnh01 View Post
I have a encoder connected to the jaguar and when testing i get rpm readings but i was wondering if it is possible to get distance readings from the encoder?
Are you calling the GetSpeed() function of the WPI lib? If so, there is also a GetPosition() function that returns the encoder position. You can derive the distance from it with information such as your gear ratio and wheel diameter.
